I’ve been waiting to upgrade my hass until it’s included since I manually edited my files for the patch.
But I don’t understand when I’m likely to see it? I can see the rc branch on github is miles behind dev, can someone point me to info on the process of merging dev to rc please?
I see, cheers, guess I’ll update and re-patch then any simpler way to edit core files on haos than sshing into the core docker container? Like pointing something at my own docker image/GitHub repo?
Your PR has been reviewed and merged into dev. Most likely it will be in the 2022.6.0 release, early June.
Google led me to here: Releases - Home Assistant
If anyone else finds this, I made a patches folder in my homeassistant config directory then copied the relevant file over, then saved this as a bash script (must be run as root or in SSH addon without protection mode) - easy to re-run it after each update until the patch is released!
