Hello
I am struggling of getting reliable control of Heat Pump which is equipped with Husdata.
Husdata itself in autoconfigure mode does generate climate enities.
By reliable I mean to make userproof lovelance card but I thought cause of my problems are more configuration. So that if antything is happening with HA/Hustada/Heat pump Modes and temperatures will be same in all places. Perfect thing is how climate temp does this: If You set temperature it goes red until HA gets feedback from Heatpump state (Husdata) that this is equal to what You have set.
Problem is that I have diffrent modes (OFF, AUTO, HEAT PUMP; HEATER; WARM WATER) than mqtt climate allows to.
Presets are just semi solution because with thermostat card You cant set them up and with entity card You do not get confirmation about what mode has been setted up currently.
Ofcourse there will be probably whole dashboard (grapht, picture elements etc) dedicated to climate/heating with many cards but I want to keep control of simple as it can be.
Another solution that I have investigated is nervetattoo / simple-thermostat but it is realying on already existing entities and I just can`t get my head around how to make it my way.
Edit: After one day thinking about it I can just put 2 new entities that will check if HA entities are equal to what Husdata module is reporting and if they are not color values in card in red. Additionally I could just set up automation to update them on mismatch. But in that case i will not be able to change these two values directly on heat pump. Any ideas?
Now since after card-mod improvements it is complete:
Picture elements card:
THP sensors are optional (easy to cut out of picture)
type: picture-elements
elements:
- entity: sensor.radiator_return
style:
left: 69%
top: 59%
type: state-label
- entity: sensor.radiator_forward
style:
left: 69%
top: 73%
type: state-label
- entity: sensor.brine_in_evaporator
style:
left: 20%
top: 76%
type: state-label
- entity: sensor.brine_out_condenser
style:
left: 20%
top: 57%
type: state-label
- entity: sensor.warm_water_1_top
style:
left: 47%
top: 38%
type: state-label
- entity: sensor.thp_lazienka_gora_temperature
style:
left: 80%
top: 32%
type: state-label
- entity: sensor.thp_salon_temperature
style:
left: 80%
top: 50%
type: state-label
- entity: sensor.thp_ext_temperature
style:
left: 11%
top: 28%
type: state-label
- entity: sensor.outdoor
style:
left: 11%
top: 45%
type: state-label
- entity: sensor.pressure_tube
style:
left: 47%
top: 77%
type: state-label
- entity: binary_sensor.add_heat_step_1
style:
left: 42%
top: 50%
type: state-icon
- entity: binary_sensor.add_heat_step_2
style:
left: 51%
top: 50%
type: state-icon
- entity: sensor.danfosspraca
show_state: false
show_name: false
state:
- color: red
value: ERR
- color: grey
value: 'OFF'
- color: orange
value: CWU
- color: yellow
value: CO
style:
left: 46.5%
top: 66%
icon:
- width: 50%
styles:
card:
- '--ha-card-background': rgba(0, 0, 0, 0.0)
- '--ha-card-box-shadow': none
type: custom:button-card
image: /local/pc.png?v=4
Picture:
Adjustment Card requiring card-mod:
type: entities
entities:
- entity: input_number.pctemp
secondary_info: none
card_mod:
style: |
:host {
{% if is_state('sensor.danfosstempcheck', '0') %}
color: orange;
{% elif is_state('sensor.danfosstempcheck', '1') %}
color: white
{% else %}
color: red;
{% endif %}
- entity: input_select.pctryb
card_mod:
style:
ha-select $: |
span.mdc-select__selected-text {
{% if is_state('sensor.danfossmodecheck', '0') %}
color: orange !important;
{% elif is_state('sensor.danfossmodecheck', '1') %}
color: white !important;
{% else %}
color: red !important;
{% endif %}
- entity: sensor.alarm_code
title: DANFOSS
Custom entities to compare what is in HA inputs and what Husdata is reporting:
#Check Mode HP input
sensors:
danfossmodecheck:
friendly_name: "Danfoss Mode Check"
value_template: >
{% set mapper =
{'0' : 'OFF',
'1' : 'AUTO',
'2' : 'POMPA CIEPŁA',
'3' : 'PODGRZEWACZ',
'4' : 'CWU'} %}
{% set state = state_attr('climate.operating_mode_1', 'temperature') | int | string %}
{% set value = mapper[state] if state in mapper else 'ERR' %}
{% if states('input_select.pctryb') == value %}
{{ 1 }}
{% else %}
{{ 0 }}
{% endif %}
#Check Temp HP input
sensors:
danfosstempcheck:
friendly_name: "Danfoss Temp Check"
value_template: >
{% if states('input_number.pctemp') | float(default=0) == state_attr('climate.room_temp_setpoint', 'temperature') | float(default=0) %}
{{ 1 }}
{% else %}
{{ 0 }}
{% endif %}
# Interpreter of what HP is really doing based on Compressor mode and Valve positions with dedicated mdi to reflect it on image.
sensors:
danfosspraca:
friendly_name: "Tryb Pracy"
value_template: >
{% if is_state('binary_sensor.compressor', 'on') and is_state('binary_sensor.switch_valve_1', 'on') %}
{{ 'CWU' }}
{% elif is_state('binary_sensor.compressor', 'on') and is_state('binary_sensor.switch_valve_1', 'off') %}
{{ 'CO' }}
{% elif is_state('binary_sensor.compressor', 'off') and is_state('binary_sensor.switch_valve_1', 'on') %}
{{ 'Zmiana Cyklu'}}
{% elif is_state('binary_sensor.compressor', 'off') and is_state('binary_sensor.switch_valve_1', 'off') %}
{{ 'OFF'}}
{% else %}
{{ 'ERR' }}
{% endif %}
icon_template: >-
mdi:arrow-up-box
mdi:arrow-right-box
mdi:call-split
mdi:file-excel-box
{% else %}
mdi:image-broken-variant
{% endif %}
Automations providing two way exchange of states for temp and mode :
- id: '1649968095561'
alias: PC Zmienia Nastawy Temperaturę Pokój PC > HA
description: ''
- platform: state
entity_id: climate.room_temp_setpoint
attribute: temperature
condition: []
- service: input_number.set_value
value: '{{state_attr(''climate.room_temp_setpoint'', ''temperature'') }}'
entity_id: input_number.pctemp
mode: single
- id: '1649003507206'
alias: PC Zmiana Nastawy Temperatury Pokój HA > PC
description: ''
- platform: state
condition: []
- service: mqtt.publish
topic: 4c752510bdbc/HP/SET/0203
payload: '{{ states(''input_number.pctemp'') }}'
mode: single
- id: '1649003236460'
alias: PC Zmiana Trybu HA > PC
description: ''
- platform: state
entity_id: input_select.pctryb
condition: []
- choose:
- conditions:
- condition: state
state: 'OFF'
sequence:
topic: 4c752510bdbc/HP/SET/2201
payload: '0'
- conditions:
- condition: state
state: AUTO
sequence:
payload: '1'
- conditions:
- condition: state
state: POMPA CIEPŁA
sequence:
payload: '2'
- conditions:
- condition: state
state: PODGRZEWACZ
sequence:
payload: '3'
- conditions:
- condition: state
state: CWU
sequence:
payload: '4'
default: []
mode: single
- id: '1649968683793'
alias: PC Zmienia Tryb PC > HA
description: ''
- platform: state
entity_id: climate.operating_mode_1
condition: []
- service: input_select.select_option
options: "{% set mapper = {'0' : 'OFF',\n '1' : 'AUTO',\n '2' : 'POMPA CIEPŁA',\n
\ '3' : 'PODGRZEWACZ',\n '4' : 'CWU'} %}\n{% set state = state_attr('climate.operating_mode_1',
'temperature') | int | string %} {% set value = mapper[state] if state in
mapper else 'ERR' %} \n {{ value }}\n"
mode: single
Counter of how many times Compressor has been switched on:
alias: Zliczanie włączeń sprężarki PC
description: ""
- platform: state
entity_id:
- binary_sensor.compressor
to: "on"
condition: []
- service: counter.increment
data: {}
entity_id: counter.pcwlaczenie
mode: single
