My Shield finally died so I went back to an ATV. The ATV does not have as good a picture as the Shield, and I really don’t like that the ATV will not pass through all audio to my high-end receiver. Too bad there are no other decent options other than the ATV. To make the ATV work, I had to add triggers and keep some state:
ATV On trigger: From off,standby —> on,idle,paused
Check to see if triggered already. If not triggered, then set triggered
From there I turn on the receiver and the TV. However, I check to make sure it isn’t between 2am and 6am. My son comes home late From work, and he said the TV was turning on after 2am. I think the ATV updates overnight, and that causes the trigger to kick off. Of course, this means that no one can turn on the system between 2am and 6am, but I can live with that.
ATV Off: If state is in off, standby for 8 seconds
Set not triggered
Turn off the receiver and TV
It’s not perfect, but it works fine 99% of the time. The key is that you have to have CEC off, at least in my system. I was never able to make the combination of the ATV, my receiver, and the TV work well together with CEC. The problem is that I also use this system for music, and I don’t want the TV on for that. With CEC, the TV would always turn on – no matter what I tried. The other issue is that the TV would shut off with CEC, but the receiver would not, even though the receiver supports CEC.
Here is what I did in NR:
[{"id":"999bd977b62e8b84","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"6e6f92d640683f13","type":"comment","z":"999bd977b62e8b84","name":"CEC doesn't shut off MX100, so shut it off here","info":"","x":320,"y":60,"wires":[]},{"id":"0577e924a84b3e0e","type":"api-call-service","z":"999bd977b62e8b84","name":"Pause WiiM","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"media_player.media_pause","floorId":[],"areaId":[],"deviceId":[],"entityId":["media_player.wiim_pro_theater"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"media_player","service":"media_pause","x":570,"y":420,"wires":[[]]},{"id":"b4615c08e2b57840","type":"server-state-changed","z":"999bd977b62e8b84","name":"MX100 Off","server":"aec342f7.5ee34","version":6,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["switch.mx100_power"],"substring":[],"regex":[]},"outputInitially":false,"stateType":"str","ifState":"off","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"2","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":200,"y":280,"wires":[["78ee0ce065d342b5"],[]]},{"id":"38b5bd735f68598e","type":"api-current-state","z":"999bd977b62e8b84","name":"ATV Standby?","server":"aec342f7.5ee34","version":3,"outputs":2,"halt_if":"off,standby,unavailable","halt_if_type":"str","halt_if_compare":"includes","entity_id":"media_player.theater_atv","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":600,"y":200,"wires":[["16ae88a490a8be16"],[]]},{"id":"a5a05de2627ccdf9","type":"link in","z":"999bd977b62e8b84","name":"Pause Theater Sonos","links":["e1dfe49d932645a2","78ee0ce065d342b5"],"x":375,"y":380,"wires":[["0577e924a84b3e0e","2b998c09e55f0de7"]]},{"id":"8b3674c6f25a8ec2","type":"server-state-changed","z":"999bd977b62e8b84","name":"ATV off","server":"aec342f7.5ee34","version":6,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["media_player.theater_atv"],"substring":[],"regex":[]},"outputInitially":false,"stateType":"str","ifState":"standby,off","ifStateType":"str","ifStateOperator":"includes","outputOnlyOnStateChange":true,"for":"8","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":190,"y":120,"wires":[["5a502cc0b5acaa2d"],[]]},{"id":"6dfc5779b5502fa3","type":"api-call-service","z":"999bd977b62e8b84","name":"Set Input ATV","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.mx100_htmi1"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_on","x":920,"y":620,"wires":[["723a3de5d3122bd5"]]},{"id":"1e3a552fb7aaf0c1","type":"api-call-service","z":"999bd977b62e8b84","name":"Set Input XBox","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.mx100_htmi2"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_on","x":920,"y":700,"wires":[["723a3de5d3122bd5"]]},{"id":"d98fa6c1c37ebcd1","type":"api-call-service","z":"999bd977b62e8b84","name":"Set Dynamic DB to Movies","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.mx100_dyneq_movies"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_on","x":1160,"y":1080,"wires":[["e1dfe49d932645a2"]]},{"id":"63cb6dbd7c67e7b3","type":"api-call-service","z":"999bd977b62e8b84","name":"Turn On MX100","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.mx100_power"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_on","x":620,"y":1080,"wires":[["caf5eae1820997ad"]]},{"id":"1ed5ef7167647607","type":"link in","z":"999bd977b62e8b84","name":"Turn mx100 for Video","links":["723a3de5d3122bd5","586e3560eacae703","62522d82522c3ce9"],"x":245,"y":1080,"wires":[["3bcce9074bc90311"]]},{"id":"723a3de5d3122bd5","type":"link out","z":"999bd977b62e8b84","name":"Turn on for video","mode":"link","links":["1ed5ef7167647607"],"x":1165,"y":660,"wires":[]},{"id":"84c1ba1f5ac613f5","type":"trigger-state","z":"999bd977b62e8b84","name":"XBox On","server":"aec342f7.5ee34","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["media_player.xboxone"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"previous_state","propertyValue":"old_state.state","comparatorType":"includes","comparatorValueDatatype":"str","comparatorValue":"off,standby"},{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"includes","comparatorValueDatatype":"str","comparatorValue":"on,idle,paused"}],"customOutputs":[],"outputInitially":false,"stateType":"str","enableInput":false,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"x":240,"y":700,"wires":[["cf193103dc11a326"],[]]},{"id":"dde5142b1846bd69","type":"config","z":"999bd977b62e8b84","name":"Triggered On Config on Startup","properties":[{"p":"triggered_on","pt":"flow","to":"false","tot":"bool"},{"p":"xbox_triggered_on","pt":"flow","to":"false","tot":"bool"}],"active":true,"x":310,"y":520,"wires":[[]]},{"id":"c8e016a30e69eaf9","type":"switch","z":"999bd977b62e8b84","name":"Not Triggered Already?","property":"triggered_on","propertyType":"flow","rules":[{"t":"false"},{"t":"true"}],"checkall":"true","repair":false,"outputs":2,"x":480,"y":620,"wires":[["6ae25105dc240357"],[]]},{"id":"6ae25105dc240357","type":"change","z":"999bd977b62e8b84","name":"Set triggered","rules":[{"t":"set","p":"triggered_on","pt":"flow","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":620,"wires":[["6dfc5779b5502fa3"]]},{"id":"49faa657a9f4d4db","type":"comment","z":"999bd977b62e8b84","name":"Putting in extra logic because ATV bounces around standby at first","info":"","x":880,"y":560,"wires":[]},{"id":"fe8c605dd0dfbe3a","type":"api-current-state","z":"999bd977b62e8b84","name":"Xbox Off?","server":"aec342f7.5ee34","version":3,"outputs":2,"halt_if":"off,unavailable","halt_if_type":"str","halt_if_compare":"includes","entity_id":"media_player.xboxone","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":580,"y":120,"wires":[["16ae88a490a8be16"],[]]},{"id":"819592f71853345b","type":"trigger-state","z":"999bd977b62e8b84","name":"ATV on","server":"aec342f7.5ee34","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["media_player.theater_atv"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"previous_state","propertyValue":"old_state.state","comparatorType":"includes","comparatorValueDatatype":"str","comparatorValue":"off,standby"},{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"includes","comparatorValueDatatype":"str","comparatorValue":"on,idle,paused"}],"customOutputs":[],"outputInitially":false,"stateType":"str","enableInput":false,"x":230,"y":620,"wires":[["c8e016a30e69eaf9"],[]]},{"id":"7c63c2f28293c9d8","type":"api-call-service","z":"999bd977b62e8b84","name":"Turn on MultiEQ","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.mx100_multieq_flat"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_on","x":400,"y":820,"wires":[[]]},{"id":"e1dfe49d932645a2","type":"link out","z":"999bd977b62e8b84","name":"Pause Theater Sonos","mode":"link","links":["a5a05de2627ccdf9"],"x":1365,"y":1080,"wires":[]},{"id":"78ee0ce065d342b5","type":"link out","z":"999bd977b62e8b84","name":"Pause Theater Sonos","mode":"link","links":["a5a05de2627ccdf9"],"x":415,"y":280,"wires":[]},{"id":"5a502cc0b5acaa2d","type":"change","z":"999bd977b62e8b84","name":"Set not triggered","rules":[{"t":"set","p":"triggered_on","pt":"flow","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":120,"wires":[["fe8c605dd0dfbe3a"]]},{"id":"38487cde2b3981d2","type":"change","z":"999bd977b62e8b84","name":"Set ATV triggered","rules":[{"t":"set","p":"triggered_on","pt":"flow","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1490,"y":600,"wires":[[]]},{"id":"bce88edcc2b69b16","type":"inject","z":"999bd977b62e8b84","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1280,"y":600,"wires":[["38487cde2b3981d2"]]},{"id":"b0a00a085e1e3cfb","type":"inject","z":"999bd977b62e8b84","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":240,"y":820,"wires":[["7c63c2f28293c9d8"]]},{"id":"7db6bf534fd278b3","type":"api-call-service","z":"999bd977b62e8b84","name":"Turn off MultiEQ","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.mx100_multieq_flat"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_off","x":400,"y":880,"wires":[[]]},{"id":"7f13574f09a7a056","type":"inject","z":"999bd977b62e8b84","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":240,"y":880,"wires":[["7db6bf534fd278b3"]]},{"id":"7605f385117f4d76","type":"api-call-service","z":"999bd977b62e8b84","name":"Turn off DynEQ","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.mx100_dyneq_off"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_on","x":840,"y":880,"wires":[[]]},{"id":"0681b2fe2a2bafaa","type":"api-call-service","z":"999bd977b62e8b84","name":"Set Dynamic DB to Movies","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.mx100_dyneq_movies"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_on","x":880,"y":820,"wires":[[]]},{"id":"5250d4cf5c39c75f","type":"inject","z":"999bd977b62e8b84","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":680,"y":880,"wires":[["7605f385117f4d76"]]},{"id":"da419048c212a8da","type":"inject","z":"999bd977b62e8b84","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":680,"y":820,"wires":[["0681b2fe2a2bafaa"]]},{"id":"92d8f5828306b01d","type":"api-call-service","z":"999bd977b62e8b84","name":"Set Dynamic DB to TV/Jazz","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.mx100_dyneq_tv_jazz"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_on","x":1380,"y":820,"wires":[[]]},{"id":"a11b594938fcd92f","type":"inject","z":"999bd977b62e8b84","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1160,"y":820,"wires":[["92d8f5828306b01d"]]},{"id":"77958dd959d85193","type":"api-call-service","z":"999bd977b62e8b84","name":"Set Dynamic DB to Pop/Rock","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.mx100_dyneq_pop_rock"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_on","x":1390,"y":880,"wires":[[]]},{"id":"93ab5659d9f9ecb0","type":"inject","z":"999bd977b62e8b84","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1160,"y":880,"wires":[["77958dd959d85193"]]},{"id":"a15282e4bbac311e","type":"inject","z":"999bd977b62e8b84","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1280,"y":640,"wires":[["25ced59e80054bb5"]]},{"id":"825daea11b859b85","type":"server-state-changed","z":"999bd977b62e8b84","name":"XBOX off","server":"aec342f7.5ee34","version":6,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["media_player.xboxone"],"substring":[],"regex":[]},"outputInitially":false,"stateType":"str","ifState":"standby,off,unavailable","ifStateType":"str","ifStateOperator":"includes","outputOnlyOnStateChange":true,"for":"2","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":200,"y":200,"wires":[["f4ce20c4b7e54c89"],[]]},{"id":"9e507dc54dfae954","type":"api-call-service","z":"999bd977b62e8b84","name":"Turn Off MX100","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.mx100_power"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_off","x":1220,"y":1300,"wires":[[]]},{"id":"7d138f779a4c88d0","type":"api-current-state","z":"999bd977b62e8b84","name":"MX100 Input","server":"aec342f7.5ee34","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.mx100_input","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"seconds","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":830,"y":1300,"wires":[["f339f8d04d19a954"]]},{"id":"f339f8d04d19a954","type":"function","z":"999bd977b62e8b84","name":"Input not music","func":"msg.payload = msg.payload.replace(/[^0-9]/g, \"\");\nif (msg.payload == \"8\" || msg.payload == \"9\") {\n return null;\n}\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":1020,"y":1300,"wires":[["9e507dc54dfae954"]]},{"id":"7c54347869f01891","type":"api-call-service","z":"999bd977b62e8b84","name":"Update input","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"homeassistant.update_entity","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"entity_id\":\"sensor.mx100_input\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"date"}],"queue":"none","blockInputOverrides":false,"domain":"homeassistant","service":"update_entity","x":650,"y":1300,"wires":[["7d138f779a4c88d0"]]},{"id":"221a1b5455a32f36","type":"api-call-service","z":"999bd977b62e8b84","name":"Turn Off Basement TV","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"media_player.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["media_player.basement_tv"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"media_player","service":"turn_off","x":440,"y":1300,"wires":[["7c54347869f01891"]]},{"id":"ce361fa1fcd740c7","type":"comment","z":"999bd977b62e8b84","name":"Shutdown video setup","info":"","x":240,"y":1180,"wires":[]},{"id":"ee172b494bb525ec","type":"comment","z":"999bd977b62e8b84","name":"Turn on video setup","info":"","x":230,"y":960,"wires":[]},{"id":"8d306dc7c792b11c","type":"link in","z":"999bd977b62e8b84","name":"Turn off mx100 for Video","links":["16ae88a490a8be16"],"x":155,"y":1300,"wires":[["221a1b5455a32f36"]]},{"id":"a8ad07a656638978","type":"inject","z":"999bd977b62e8b84","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":200,"y":1240,"wires":[["221a1b5455a32f36"]]},{"id":"16ae88a490a8be16","type":"link out","z":"999bd977b62e8b84","name":"Turn off mx100 for video","mode":"link","links":["8d306dc7c792b11c"],"x":795,"y":160,"wires":[]},{"id":"3bcce9074bc90311","type":"within-time-switch","z":"999bd977b62e8b84","name":"","nameInt":"","positionConfig":"6db3cd4f427e08bc","startTime":"02:00","startTimeType":"entered","startOffset":0,"startOffsetType":"none","startOffsetMultiplier":60000,"endTime":"06:00","endTimeType":"entered","endOffset":0,"endOffsetType":"none","endOffsetMultiplier":60000,"timeRestrictions":0,"timeRestrictionsType":"none","timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeOnlyOddWeeks":false,"timeOnlyEvenWeeks":false,"timeMonths":"*","timedatestart":"","timedateend":"","propertyStart":"","propertyStartType":"none","propertyStartCompare":"true","propertyStartThreshold":"","propertyStartThresholdType":"num","startTimeAlt":"","startTimeAltType":"entered","startOffsetAlt":0,"startOffsetAltType":"none","startOffsetAltMultiplier":60000,"propertyEnd":"","propertyEndType":"none","propertyEndCompare":"true","propertyEndThreshold":"","propertyEndThresholdType":"num","endTimeAlt":"","endTimeAltType":"entered","endOffsetAlt":0,"endOffsetAltType":"none","endOffsetAltMultiplier":60000,"withinTimeValue":"true","withinTimeValueType":"msgInput","outOfTimeValue":"false","outOfTimeValueType":"msgInput","tsCompare":"0","x":410,"y":1080,"wires":[[],["63cb6dbd7c67e7b3"]]},{"id":"084630900920ddc1","type":"comment","z":"999bd977b62e8b84","name":"Xbox sometimes wakes up to update","info":"","x":490,"y":1020,"wires":[]},{"id":"caf5eae1820997ad","type":"api-call-service","z":"999bd977b62e8b84","name":"Turn On Basement TV","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"media_player.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["media_player.basement_tv"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"media_player","service":"turn_on","x":880,"y":1080,"wires":[["d98fa6c1c37ebcd1"]]},{"id":"90b0b8defc4c3344","type":"inject","z":"999bd977b62e8b84","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":560,"y":1160,"wires":[["63cb6dbd7c67e7b3"]]},{"id":"2b998c09e55f0de7","type":"api-call-service","z":"999bd977b62e8b84","name":"Unjoin Theater","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"media_player.unjoin","floorId":[],"areaId":[],"deviceId":[],"entityId":["media_player.theater_sonos"],"labelId":[],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"media_player","service":"unjoin","x":580,"y":340,"wires":[["1b6796f5decd8dd0"]]},{"id":"1b6796f5decd8dd0","type":"delay","z":"999bd977b62e8b84","name":"","pauseType":"delay","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":780,"y":340,"wires":[["13ab46933859198f"]]},{"id":"13ab46933859198f","type":"api-call-service","z":"999bd977b62e8b84","name":"Pause Sonos","server":"aec342f7.5ee34","version":7,"debugenabled":false,"action":"media_player.media_pause","floorId":[],"areaId":[],"deviceId":[],"entityId":["media_player.theater_sonos"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"media_player","service":"media_pause","x":990,"y":340,"wires":[[]]},{"id":"cf193103dc11a326","type":"switch","z":"999bd977b62e8b84","name":"Not Triggered Already?","property":"xbox_triggered_on","propertyType":"flow","rules":[{"t":"false"},{"t":"true"}],"checkall":"true","repair":false,"outputs":2,"x":480,"y":700,"wires":[["2695bafa7a7be4ce"],[]]},{"id":"2695bafa7a7be4ce","type":"change","z":"999bd977b62e8b84","name":"Set triggered","rules":[{"t":"set","p":"xbox_triggered_on","pt":"flow","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":700,"wires":[["1e3a552fb7aaf0c1"]]},{"id":"25ced59e80054bb5","type":"change","z":"999bd977b62e8b84","name":"Set ATV not triggered","rules":[{"t":"set","p":"triggered_on","pt":"flow","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1500,"y":640,"wires":[[]]},{"id":"f4ce20c4b7e54c89","type":"change","z":"999bd977b62e8b84","name":"Set not triggered","rules":[{"t":"set","p":"xbox_triggered_on","pt":"flow","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":200,"wires":[["38b5bd735f68598e"]]},{"id":"9130b0550a17e61a","type":"inject","z":"999bd977b62e8b84","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1280,"y":680,"wires":[["1b0f96d75f212cbb"]]},{"id":"1b0f96d75f212cbb","type":"change","z":"999bd977b62e8b84","name":"Set Xbox triggered","rules":[{"t":"set","p":"xbox_triggered_on","pt":"flow","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1490,"y":680,"wires":[[]]},{"id":"92f1733b859d8f16","type":"inject","z":"999bd977b62e8b84","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1280,"y":720,"wires":[["419892118d3757b8"]]},{"id":"419892118d3757b8","type":"change","z":"999bd977b62e8b84","name":"Set Xbox not triggered","rules":[{"t":"set","p":"xbox_triggered_on","pt":"flow","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1500,"y":720,"wires":[[]]},{"id":"aec342f7.5ee34","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":true,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true},{"id":"6db3cd4f427e08bc","type":"position-config","name":"Gainesville","isValide":"true","angleType":"deg","timeZoneOffset":99,"timeZoneDST":0,"stateTimeFormat":"3","stateDateFormat":"12","contextStore":""}]
