I have noticed recently that reloading my customisations (say I add an icon or friendly name) either in a package or in customisation.yaml doesn’t reload anymore. This is for entities that I can’t edit in the GUI so I edit the customize file or package but then reloading core does nothing.
Anyone else see this?
As soon as I restart HA everything loads u correctly. Also all other reload options (themes etc) work perfectly…
yes I am calling that service via a script. It definitely used to work but isn’t anymore.
If you change an icon or a friendly_name in customize.yaml and call the service you can see it doesn’t load the ned icon/name.
Yes and the behavior is, as the saying goes, “norbal”.
The explanation for its quirky behavior can be found at the very bottom of the documentation page for Customizing Entities:
Warning
New customize information will be applied the next time the state of the entity gets updated
I customized a sensor entity by adding some information to customize.yaml. I executed Reload Location and Customizations and didn’t see, in the States view, the custom attribute I had created. However, if I wait long enough for the sensor to change state, the custom attribute appears.
Not exactly how you would expect it to behave after executing a Reload service but that’s it’s “norbal” behavior.
