Reload scripts.yaml gone after 113?
Hi, I cant seem to find the reload scripts.yaml and other where they were before “Server management”, I could not find any note about them being moved or deleted, any suggestions to where to find those functions? I was always using them to check my configuration.yaml after any changes to make sure it was correct.
That’s because it isn’t removed. So if it’s not there, there is something wrong with your installation.
Well that is good to know, how can I fault search this?
This is how it looks for me:
Logg looks like this (nothing related to this):
Here is a complete log straight after reboot:
2020-08-08 11:06:13 WARNING (SyncWorker_5) [pyhik.hikvision] Sensor type “faceSnap” is unsupported.
2020-08-08 11:06:14 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.0
2020-08-08 11:06:14 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 5 seconds
2020-08-08 11:06:15 WARNING (MainThread) [homeassistant.components.onvif] The date/time on the device (UTC) is ‘2020-08-08 09:06:44+00:00’, which is different from the system ‘2020-08-08 09:06:15.527554+00:00’, this could lead to authentication issues
2020-08-08 11:06:19 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.0
2020-08-08 11:06:19 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 10 seconds
2020-08-08 11:06:29 ERROR (stream_worker) [libav.h264] error while decoding MB 59 53, bytestream -14
2020-08-08 11:06:29 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.0
2020-08-08 11:06:29 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 20 seconds
2020-08-08 11:06:30 ERROR (MainThread) [homeassistant.components.script.1595918828966] Camera snapshot loop: Error rendering Camera snapshot loop delay template: offset 00:00:01:000 should be format ‘HH:MM’ or ‘HH:MM:SS’
2020-08-08 11:06:49 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.0
2020-08-08 11:06:49 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 40 seconds
2020-08-08 11:07:29 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.0
2020-08-08 11:07:29 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
2020-08-08 11:08:49 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.0
2020-08-08 11:08:49 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
Do you have advanced mode on or off in your profile?
That was easy, advanced mode was off for some reason, thank you!
Now everything is back as it should
