thanks Petro, will test that.
edit
this doesn’t help unfortunately:
binary_sensor:
sensors:
battery_alert:
friendly_name: Battery alert
device_class: problem
availability_template: >
{{ states('sensor.low_level_batteries') not in ['unknown','unavailable','None'] }}
value_template: >
{{states('sensor.low_level_batteries')|int > 0}}
attribute_templates:
Count: >
{{states('sensor.low_level_batteries')|int}}
List: >
{{state_attr('sensor.low_level_batteries','List Low')}}
btw, Ive tested to dont use the |int
along with > '0'
which seems to help too. maybe hacky, but still.
digging some further, there’s 1 other automation triggered by a binary that gets fired. Odd thing is, this is 1 of 2 binaries checking for quakes, 1 for general quakes at all, one for quakes near.
earthquakes_active:
friendly_name: Earthquakes active
value_template: >
{{states('sensor.earthquakes')|int > 0}}
device_class: safety
earthquakes_near_active:
friendly_name: Earthquakes near active
value_template: >
{{states('sensor.earthquakes_near')|int > 0}}
the template sensors they are based on are:
earthquakes:
value_template: >
{{states.geo_location|selectattr('attributes.source','eq','usgs_earthquakes_feed')
|list|count}}
list: >
{% if states.geo_location|selectattr('attributes.source','eq','usgs_earthquakes_feed')
|list|count > 0 %}
|map(attribute='name')|join(',\n')}}
{% else %} No Quakes registered
{% endif %}
earthquakes_near:
friendly_name: Quakes near
value_template: >
{% set km = states('input_number.quakes_near')|float %}
{% set location = states('input_select.quakes_near') %}
{% set ns = namespace(count=0) %}
{% for s in states.geo_location|selectattr('attributes.source','eq','usgs_earthquakes_feed')
if distance(s.entity_id,location) < km %}
{% set ns.count = ns.count + 1 %}
{% endfor %}
{{ns.count}}
of these, the generic quakes binary triggers this automation:
- alias: Quake Alert
platform: state
entity_id: binary_sensor.earthquakes_active
to: 'on'
why is this triggering and the other more complex one not, on reload of templates, I must find out. Probably because the quake template doesnt use |int inside the template itself (so it might be hacky by design? and the quakes_near uses the function distance(), which solves the issue.
because I also tried
{%- set ns = namespace(below=0) %}
{%- for s in expand('group.battery_sensors')
if s.state|int < states('input_number.battery_alert_level')|int %}
{%- set ns.below = ns.below + 1 %}
{%- endfor %}
{{ns.below}}
but this still |int 's unknown states to 0, so will always make it trigger… And I can see that because at startup most of the battery sensors are displayed as unknown%, in the list:
List Low: >
{%- set alert_level = states('input_number.battery_alert_level')|int %}
{%- set count = expand('group.battery_sensors')
|map(attribute='state')|map('int')
|select('<',alert_level)
|list|count %}
{% set phrase = 'battery is' if count == 1 else 'batteries are' %}
{%- if count > 0 %}
if s.state not in ['unknown','unavailable','None'] and
s.state|int < alert_level %}
{%- if loop.first %}{{loop.length}} {{phrase}} below {{alert_level}} %: {% endif %}
{{s.name + ': ('+ s.state + '%),\n'}}
{%- endfor %}
{%- else %} All batteries above {{alert_level}} %
{%- endif %}
so I hope to have excluded that with the if s.state not in ['unknown','unavailable','None']
to be continued
Why this didn’t trigger before 115 is a question too…
