The integration also works with my eTwist on Remeha Avanta Ace 28C
This does not work for me. I allready paired it with my phone but pairing with HA does not work for me.
I tried to connect the etwist to an OTGW that connects to a Tzerra Ace 28C.
The etwist did not want to turn on in this configuration. After removing the OTGW (so now having the etwist connecting to the Tzerra Ace 28C directly) it also does not want to turn on.
It was mentioned that this could be explained by the Tzerra expecting OT instead of R-bus instructions.
Does someone know how to reset things such that the etwist to Tzerra Ace connection works again?
Do you know how to reset/change the boiler such that it will work with the etwist again?
Hello everyone,
I have a new central heating boiler Tzerra Ace from Rehema, , Also an new etwist is connected too at gound floor. May I know if I can connect another Honeywell thermostat to the bolier at the same time at 2nd floor? How to have two thermostats in different floor work with one boiler?
Regards
Henry
Hi, Firs of all, thank you for the code you made. it works fine for me. I wonder if there is a way to add more parameters related to the hot water settings for example ? I tried to look into the code but too complicated for me I want to control the boiler heating time when I am sending back power to the grid … Thanks again
Thnx, the Integration works on a Remeha Tzerra Ace 39c
