Remeha Etwist thermostat
Hello everyone,
I have a new central heating boiler from Rehema, a Tzerra Ace, which has several communication methods, including its own serial bus with which you can monitor the boiler with a service tool and the like, but I cannot find a pinout for this boiler unfortunately …
But it also communicates via Open-Therm and Etwist / R-bus, at the moment I have an open therm gateway between the boiler and the (open-therm) room thermostat, but I am going to use an Etwist thermostat for it (still to be delivered ) which can also be operated via the remeha etwist app, google home and IFTTT.
Now I wondered if this etwist can also be linked directly to Home_Assistent without needing the open therm gateway anymore.
the advantage of this is that I can connect the Etwist thermostat directly to the boiler without having to convert the open therm to R-bus first, so less chance of errors, and probably better communication?
I myself am not at home is google Home or IFTTT, but who knows, who knows, with some help?
thank you in advance.
dzjr
Hi, I’m getting my new Remeha heating boiler with eTwist Thermostat next month. I already did some searching and found a method using IFTTT, but my experiences with IFTTT recently were disappointing, so i’m looking for other, more reliable ways. I’ll let you know when i find something usable.
Hi, I’m getting my new Remeha heating boiler with eTwist Thermostat end of this month. I’d be really interested if you do find something!
Did you find a way to make this setup work?
I can’t get it to work via the ETWIST, only some IFTTT messages, but I don’t get any malfunction and status messages such as water pressure, burner status, etc.
so I now have the etwist GW after my OT Gateway, and the OT Gateway is then connected to HA again, I already had this function running, so actually only use the ETWIST as a clock thermostat which I can easily operate.
So it could also be done with HA itself, but then you always have to open HA, and provide a th sensor yourself
Ok i will have to do some more research then, i don’t have a OT gateway yet and my Etwist is connected to the R-Bus. Is it also possible with it connected to the R-Bus or do i need to get the etwist gateway as well? Thanks for the help. Really appreciate it
I think you can connect the Etwist directly to the R-Bus, if your boiler supports that (Remeha Ace?) of course.
I already had the OT Gateway running, and I would like to read the current data, so I did it like this.
Saw that others had done research, but that Remeha doesn’t release anything…
and through IFTTT you only have limited options.
Yes it’s the calenta ace. I have it connected to the R-Bus. And have the app working but i want it in my HA system as well. So if I add the OT gateway this should be possible right.
Yes, with the otgw you van monitor all the signals from the boiler, And Read them into ha.
If you use a otgw you also need a etwist gateway.
Thanks i’m going to try it.
Nope, no go. Bummer.
Oh well… at least i can now program the thermostat with my mobile phone. Big improvement. :slight_smile:
So I have the Calenta Ace40c boiler with a Etwist thermostat. I now have the otgw connected and in HA, I don’t have the etwist gateway, suppose to be installed in the boiler already with the ace. But my Etwist doesn’t turn on anymore. Do I really need an etwist gateway as well? And do i have some wiring wrong since the thermostat doesn’t turn on anymore? This is how i have it connected:
The black wires go to the r-bus of the boiler, and the orange and blue go to the thermostat.
And this is how it looks in HA
The boiler has 3 differerent modes On\Off, Open-Therm & Remeha Protocol.
The Etwist works witht the remeha protocol and is no longer working if you connect the open therm gateway becouse the boiler will go to open therm mode. I have the same boiler and connected a Honywell Thermostat with the Open Therm Gateway now everything is working fine.
Thanks for the info!
I just found out about another way to connect the etwist to HA.
I made a small modification to BDRthermostatHA you can find it here: https://github.com/freitdav/BDRthermostatHA/pull/2.
Please let me know if it works for you
Hi @MMoerdijk1, maybe a very stupid or stupid question, but how can I add your integration to HA?
Great, this was just what I was looking for.
I needed to do some small fixes, but now it works!!
I installed the integration via HACS, first via the old version, where I have to enter the pairing code, then I got error messages, now I have run the update where I only have to enter the email and password, I’m sure it’s the right one has been seen in the app it does work, and then I get an error message, with the following log messages
Can someone tell me what I’m doing wrong?
2022-07-27 16:53:21 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry BDR Thermostat for bdr_thermostat
File "/config/custom_components/bdr_thermostat/__init__.py", line 59, in async_setup_entry
File "/config/custom_components/bdr_thermostat/BdrAPI.py", line 46, in bootstrap
File "/config/custom_components/bdr_thermostat/BdrAPI.py", line 71, in _login
File "/config/custom_components/bdr_thermostat/BdrAPI.py", line 117, in async_post_request
File "/config/custom_components/bdr_thermostat/BdrAPI.py", line 106, in _sync_request
File "/config/custom_components/bdr_thermostat/BdrAPI.py", line 103, in _sync_request
Im stuck having to add a pairing code which I dont have. How do I fix this?
Go to settings on your Thermostat, add device and request an paring Code.
It the same procedure as for the app
