Remembering states
I know this have been covered in other threads but my question is slightly different!
I would like to remember the state of my WLED’s so that after the automation they can revert back, I have the automation setup to create a scene and reload it which works ok, but… I would like to remember the colour, brightness and effect as well as if the WLED’s were on.
I have had a play around with some code but I cannot get it to work, can anyone help?
Also can one scene remember the states for two different lights? ie WLED1 and WLED2?
service: scene.create
  scene_id: alert_revert
  snapshot_entities: 'wled.effect,light.xmas_wled'
Regards
James
Maybe take a look at this:
There are a couple options. You could use scene.create to maybe do this. Or you could push the state to an input_text as a concatenated string and then read it back later.
I’m not sure how to write that offhand. You’d use Jinja for that.
You can create input boolean in configuration.yaml like this:
input_boolean:
  scene_saved:
and this is example of a part of my yard automation using it:
  - service: scene.create
      scene_id: yard_before
      snapshot_entities:
      - light.front_garage
      - light.front_1
      - light.front_2
      - light.front_wall
  - scene: scene.front_bright
    entity_id: input_boolean.scene_saved
- alias: No Motion Restore Front Lights
    platform: state
    entity_id: binary_sensor.garage_outside_sensor_motion
    to: 'off'
    for:
      minutes: 2
  - service: scene.turn_on
      entity_id: scene.yard_before
  - service: input_boolean.turn_off
