so I would like to track the odometer reading of my EV since last charge. I’ve created a template sensor:
template:
- trigger:
- platform: state
entity_id:
- sensor.citroen_ec4_charging_mode
- Quick
- Slow
to: No
- name: "Citroen EC4 Last Charge Finished Mileage"
state: "{{ states('sensor.citroen_ec4_mileage') }}"
- name: "Citroen EC4 Last Charge Finished Battery Level"
state: "{{ states('sensor.citroen_ec4_battery_level') }}"
But afaik it looses value if I restart hass. And that if I understand correctly is expected. Any work around to this?
Another way would be to probably use automation + input_number sensor, and then as automation action use a input_number.set_value service. This way the input number would be persisted across hass reboots?
Thanks, I was just under impression that I also need to do something not just copy paste
Anyhow, it does seem that home assistant restarting is not the only issue. Though the sensor.citroen_ec4_charging_mode changed couple of times today, this template stayed in the “unknown” state, so will have to see what is up with that
I deleted my original post because, based on the documentation and tests I have performed, a Trigger-based Template Sensor’s state is restored after a restart.
The state, including attributes, of trigger-based sensors and binary sensors is restored when Home Assistant is restarted.
Your two Trigger-based Template Sensors simply report the value of two Citroen-based sensors. You should confirm that those two Citroen sensors (mileage/battery_level) report proper values at all times, even after startup.
If your two Trigger-based Template Sensors fail to update at all times then there’s a problem with the State Trigger (follow the advice from mobile.andrew.jones regarding the spelling of the state values).
I’ve plugged/unplugged the car three times yesterday, and the template sensor stayed in the unknown state.
Tried changing from to not_from, no luck either
not_from:
- "unknown"
- "unavailable"
to: "No"
Then I decided to add an automation with input number instead.
automation:
- alias: Set After charge mileage
- platform: state
entity_id:
not_from:
- "unknown"
- "unavailable"
to: "No"
service: input_number.set_value
entity_id: input_number.citroen_ec4_last_charge_finished_mileage_test
value: "{{ states('sensor.citroen_ec4_mileage') }}"
input_number:
citroen_ec4_last_charge_finished_mileage_test:
name: Citroen EC4 Last Charge Finished Mileage
min: 0
max: 999999
unit_of_measurement: km
plugged/unplugged, and bam - automation with input_number seemed to work. Thinking that I’m just gonna stick to that went to delete the template sensor, and surprise surprise - that one also had a value!
So probably gonna leave those two for a while to see if they always work
