Reminders and/or todo lists
I would like to see reminders and/or todo lists that can be updated remotely.
features needed are:
ability to link a reminder or list to a tracked device or automation.
add, remove, view remotely and in the local ui without having to edit the config yaml.
simple way to add a geofence to a reminder via remote access.
There’s a PR in process for adding Google Calendar support so when this is merged you can use that…
I went the google calendar route and it seemed a bit annoying for the family to use specific syntax etc.
I think a simple list below with options for recurring would be great. Perhaps to only show up a week prior to the event?
Change HVAC Filter: June 1st, 2017
Change Fridge Water Filter: July 2nd, 2017
Cousin Mike’s Wedding: August 5th, 2017
Grass fertilizer: August 24th, 2017
Car Oil Change: September 9th, 2017
