Reminders via Assist - Create and List Tasks with Conversational Commands
Hi everyone! ![]()
I’m super excited to give back to the Home Assistant community – after benefiting from so many shared resources, I can finally contribute something of my own. This blueprint has been a fun project, and I hope it helps improve your Home Assistant setup!
Don’t forget to expose the automation to Assist too! It will help the new Fallback LLM handle edge cases
NOTE: the blueprint mode is set to “single” for now because “queued” seems to cause a bug where the conversation response no longer works correctly. This isn’t ideal, but I’ll keep it like this for now until the bug is fixed.
What does this blueprint do?
This automation aims to replicate the behaviour of Google Assistant’s reminders via voice. You can set reminders and fetch a list of your pending tasks using conversational commands. It supports both relative and exact time inputs and even tries to deduce whether you meant 2 AM or 2 PM based on the context.
Inspiration
I was originally inspired by this post on local voice reminders. After trying it out, I wanted to create a slimmer version of the same idea that worked entirely within a single automation and didn’t require any additional YAML tweaking. Doing it this way also made it easy to share as a blueprint—something I was keen on!
Features:
- Add reminders with commands like:
- “Remind me to water the plants tomorrow.”
- “Set a reminder to call mom at 3 PM.”
- Fetch your task list by saying:
- “What’s on my reminder list?”
- “Show me my tasks.”
- Customizable to work with your preferred to-do list entity and voice commands.
- Tailor the voice commands to your liking
How to use:
- Import blueprint file into your Home Assistant instance.
- Reload automation (this may not be required, but when I was testing this import, some issues cropped up if I didn’t reload).
Reminders YAML
blueprint:
name: Reminders - Create and List
description: "Effortlessly set reminders and fetch tasks using conversational commands. This automation supports relative and exact time inputs, intelligently deducing 2 AM or 2 PM based on context for a seamless experience."
domain: automation
input:
todo_entity:
description: The entity ID of the todo list to store reminders.
selector:
entity:
domain: todo
add_reminder_commands:
name: Add Reminder Commands
description: List of conversational commands for adding reminders.
default:
- Remind me to {reminder} [at] {datetime}
- I need to remember to {reminder} [at] {datetime}
- Set a reminder [to] {reminder} {datetime}
- Can you remind me about {reminder} at {datetime}
- Remind me in {datetime} to {reminder}
- In {datetime} remind me to {reminder}
- Add {reminder} to my (tasks|reminders|to do list) for {datetime}
- Add [a] reminder [to] {reminder} {datetime}
- Remind me tomorrow [to] {reminder}
- Please remind me next week to {reminder}
- Remind me to {reminder} in {datetime}
- Schedule {reminder} {datetime}
fetch_reminder_commands:
name: Fetch Reminder Commands
description: List of conversational commands for fetching reminders.
default:
- What tasks (are left|remain|are incomplete)
- Whats on (the|my) reminder list
(What are|Tell me|Read|List|Show me) [(my|the)] [pending]
(reminders|tasks|to-do list)
- platform: conversation
command: !input add_reminder_commands
command: !input fetch_reminder_commands
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- variables:
reminder: >
{% set slots = trigger.slots | default({}) %}
{{ slots.reminder if slots.reminder else "No reminder specified" }}
raw_datetime: >
{{ slots.datetime if slots.datetime else "none" }}
- variables:
due_date_str: >
{% set raw_datetime = raw_datetime | string %}
{% if raw_datetime == 'none' %}
{{ now().strftime('%Y-%m-%d %H:%M:%S') }}
{% elif 'minute' in raw_datetime or 'hour' in raw_datetime %}
{{ (now() + timedelta(seconds=raw_datetime | regex_replace(find='[^0-9]', replace='') | int * 60)).strftime('%Y-%m-%d %H:%M:%S') }}
{% elif ':' in raw_datetime and ('AM' in raw_datetime or 'PM' in raw_datetime) %}
{% set time_24h = strptime(raw_datetime, '%I:%M %p').strftime('%H:%M') %}
{{ as_timestamp(now().strftime('%Y-%m-%d') + ' ' + time_24h) | timestamp_custom('%Y-%m-%d %H:%M:%S', true) }}
{% elif ':' in raw_datetime %}
{% set time_object = strptime(raw_datetime, '%H:%M') %}
{% set now_time = now().replace(second=0, microsecond=0) %}
{% set parsed_time = now().replace(hour=time_object.hour, minute=time_object.minute, second=0, microsecond=0) %}
{% if parsed_time < now_time %}
{% set parsed_time = parsed_time + timedelta(days=1) %}
{% endif %}
{{ parsed_time.strftime('%Y-%m-%d %H:%M:%S') }}
{% elif 'AM' in raw_datetime or 'PM' in raw_datetime %}
{% set time_24h = strptime(raw_datetime, '%I %p').strftime('%H:%M') %}
{% elif raw_datetime.isdigit() %}
{% set hour = raw_datetime | int %}
{% set am_time = now().replace(hour=hour, minute=0, second=0, microsecond=0) %}
{% set pm_time = now().replace(hour=(hour + 12) % 24, minute=0, second=0, microsecond=0) %}
{% if am_time < now() %}
{% set am_time = am_time + timedelta(days=1) %}
{% endif %}
{% if pm_time < now() %}
{% set pm_time = pm_time + timedelta(days=1) %}
{% endif %}
{% set parsed_time = am_time if am_time < pm_time else pm_time %}
{% else %}
{{ as_timestamp(raw_datetime) | timestamp_custom('%Y-%m-%d %H:%M:%S', true) }}
{% endif %}
- service: todo.add_item
item: "{{ reminder }}"
due_datetime: "{{ due_date_str }}"
description: >-
Created by voice command on {{ now() }}. Original request was
'{{ trigger.user_input.text }}'.
entity_id: !input todo_entity
- delay:
hours: 0
minutes: 0
seconds: 2
- set_conversation_response: "Done, I will remind you to {{ reminder }} on {{ due_date_str }}."
- conditions:
sequence:
- service: todo.get_items
status: [needs_action]
response_variable: tasks
- set_conversation_response: >-
{% if tasks['!input todo_entity']['items'] | length == 0 %}
You have no outstanding tasks.
{% else %}
You have {{ tasks['!input todo_entity']['items'] | length }} tasks pending. Here are your tasks:
{% for task in tasks['!input todo_entity']['items'] %}
- {{ task['summary'] }}
{% if task['due'] is defined and task['due'] | as_timestamp(default=None) is not none %}
(Due at: {{
task['due'] | as_timestamp | timestamp_custom("%-d %B at %-I:%M %p", true)
{% endif %}
{% endfor %}
{% endif %}
mode: single
Configurable inputs:
- Reminder Entity: Set this to the to-do list where you want tasks to be stored.
- Command Lists: Customise the phrases for adding and fetching tasks.
I’d love to hear how it works for you or if you have suggestions for improving it. Thanks for checking it out, and I hope it makes managing reminders a bit easier! ![]()
