Error handling request
20:25:54 – (ERROR) /lsiopy/lib/python3.11/site-packages/aiohttp/web_protocol.py
Unable to install package aioremootio @ git+https://github.com/peaceduck/aioremootio: ERROR: Error [Errno 2] No such file or directory: ‘git’ while executing command git version ERROR: Cannot find command ‘git’ - do you have ‘git’ installed and in your PATH?
20:25:54 – (ERROR) util/package.py - message first occurred at 20:25:49 and shows up 3 times
Hello. HA installed as Docker under UNRAID storage. Every other integration is working well, including integrations under HACS. I am unable to fix this issue still, I tried both ways, your git repo and also original repo with modification in py files, nothing works. Same error for both.
Core 2023.11.3, Frontend 20231030.2
Sorry, I have been very busy at work. I am still att 2023.11.
I am not sure if I will have time to look at it before Christmas. But I will really try to take a closer look after Christmas. It is very annoying that it breaks all the time. I will try to find time to investigate this in more detail so we can get a stable integration. If I can, I will check before Christmas, but no promises there.
A bit of a blind test here, since I do not have the time at the moment to update HA.
But I saw a discussion on GitHub on this, and I did change the version strings. So if anyone with 2023.12 have time, you could try to update mine to 2.0.1. I have updated the requirements.txt (which I did not totally understand, when I looked at the documentation now…)
I installed the peaceduck HACS remootio 2.0.1 thing but i dont find the config page for it in HA after installation. Can someone guide me where it is supposed to be?
Currently running HA 2024.2.1
I am just trying to set it up too (HA 2024.2.1), added the peaceduck repo in HACS, then in Settings > Devices & Services > Add Integration > Remootio Smart Garage Door Opener
You then get the config of the IP and API secret/auth keys.
I think you need to restart HA after you have added it so it reads the config - you need to do a restart at some point.
I get a wait after entering my config but then get an “Unexpected Error”. Not clear to me where I can look to determine what may be happening here. And ideas?
