Remote Access - 2025
Hi there. I wanted to seek advice on remote access. I know there are many posts, and I have read them all. However, for all the options there seems to be a plethora of discord including dire security warnings. Most solutions or addons are constrained to some abstract or constrained to HA specific walled garden type implementation.
I basically have one use case currently. I want my mobile device (companion app) to report location for geofencing automation (namely arming my Bosch Alarm - I have the HA Integration installed and working).
Other companion app features are a nice-to-have. Currently when I leave my house I loose connection and the geofence is not properly triggered. I am aware of the below options…
  • Cassa/Remote paid - Overkill for me, and I’d rather build something myself.
  • Direct port forward - Rather not expose my WAN IP.
  • Coming in through Cloudflared tunnel - This is the most viable since I already have one set up.
  • Addons like NGINX, DuckDNS, Letsencrypt - These seem specific to HA and I don’t really need the features these provide as I have it covered elsewhere on my network. I must say doco for these hasn’t been great. Just some basic yaml config with no real explanation how they dovetail into a remote setup. I don’t think I need yet another NGINX proxy. Lets encrypt add-on seems broken. Cloudflare API doesn’t validate and there’s no HTTP pathway to my HAOS for HTTP validation - at least not permanently.
  • SD Networking like ZeroTier as a VPN, or a VPN like WireGuard - This would be good but the client apps don’t turn on automatically very well when you’re away from home or you have to set up a VPN server, plus they use phone battery and are not easy to transparently set up on other family member’s phones.
  • Connecting directly to the Bosch Cloud API directly
My real main question here is… How do I best/safely get the companion app working remotely on my existing home web-server setup (see background below)? I can figure out the Cloudflared/firewall/HTTPS side I just need to know where to configure HAOS.
Do I just point at the HAOS IP port 8123? Setting up SSL with a custom IP has been challenging for me in HA as everything is abstracted away. Seems silly having another local NGINX proxy - is it not safe to use the existing HAOS webserver and force TLS? How do you do that?
Background
I host a couple of other websites through a Cloudflare tunnel and dedicated Proxmox Container running a dedicated reverse NGINX proxy on the same CT, and the websites are on separate virtual machines/containners… much like my HAOS.
I’m trialing WireGuard + Tasker (where tasker enables WireGuard in the absence of a home WiFi connection).
Hopefully it’s reliable. Has the added benefit of DNS Pihole ad blocking of my home network plus access to various other services at home.
I have a few HAOS sites and none of them are exposed to the internet.
I have the edge router or firewall provide WireGuard or OpenVPN VPN. I have HA companion app on my laptop and my mobile phones. I just pick which site to connect to, then fire up the app like I was on site.
This works for me as some of the sites are only up temporarily, have intermittent internet connection, or the internet connection have to be set up manually.
Setup works occasionally, however, I am finding HA a bit unreliable deciding when I’m “Away”. I drove away and nothing happened for 10 minutes. Then I unlocked my phone and opened the HA Companion app and it said I was home. After interacting with it quite a bit it finally changed to Away. It had been over 15 minutes.
I have the companion app with full battery, do not optimise, GPS high accuracy, background data.
Can the companion app expose what SSID I’m connected to? I feel like whether I’m on home wifi or not for some threshold would be a better indicator of whether I’m home or away.
Yes, look at the network sensors in the app.
That’s what I use.
Another option you didn’t list for remote access is Tailscale. IMO for something like this where you don’t need/want to tunnel all the traffic over the VPN it’s a really good solution.
Cloudflare tunnels are (IMO) a great option if you’re already using it. My own setup includes CF tunnels, which like yours connect to a reverse proxy (Traefik) that then handles the connections.
What am I missing here?
The companion app can expose what AP it is connected to so it’s possible, without any extra’s, to determine whether you’re home (or not)
Sure, but some blueprints and integrations expect a device_tracker, rather than a simple sensor. For instance you can link a person only to device_trackers.
I link my person to that “fake” device tracker to determine home/away, then I can use the state of zone.home to see how many people are home.
As far as I know, this very much depends on how you set up your user account. Go to
Settings --> People --> [select the user using the phone] in question.
On the bottom you will see Slect the devices that belong to this person. This is where “Away” comes from. Using those things are how HA figures out if you are Home or Away. I use multiple items, e.g., the cell phone, BT watch, wifi connection on the network by the cell phone (device tracker). It works well enough for my needs, about 60 to 180 seconds.
after a 2 years period using DDNS and nginx, I switched to Tor addon.
It’s amazingly easy to setup, very reliable (never had a disconnection on tor network, while on ddns I did more than sometimes, probably also for not so easy setup procedures) and it’s absolutely private. If you want you can also install ssl certificates on your orbot VPN (the app you have to install on your android phone to be able to connect to tor network) and prevent anyone to even see your istance on the network.
As I mentioned, I use android, I don’t know about the IOS alternative or if there’s one, however I’m very happy with that. The only con I can think of is that using orbot VPN with a constant connection drains some battery. In my case I don’t use persistent connection, so not a problem for me, but it could be an issue in many cases.
Interesting! Is there any tutorial for setting up Tor and remote access?
I have been using HA quite some time, and didnt know that is possible to use this method to access HA from the outside without redirecting ports apart of HA Cloud.
I followed the setup documentation here:
I forgot to mention that another pro of this addon is that you don’t need a NAT loopback capable router, which is required for DDNS and nginx to work, which IMO is the reason why so many people, including me untill tor, is still experiencing connection issues as of today.
For home and away automations I placed a smart switch inside the house near the entrance door and made its state ON trigger a “Home” automation and its state off trigger an “Away” one. When I enter or leave, I just push the button. That’s the most safe, easy and reliable way I found.
Hello there!
I’ve been a long time user of Home Assistant and I’ve tried each of the options you mentioned. The one that stuck is by using Tailscale (similar to zerotier) to access Home Assistant (and my homelab in general).
I understand the disconnection issue on phones, at first I was quite frustrated by it. But I have an android phone and I toggled the option to keep it always on and deactivated battery optimisation options. I didn’t notice any significant draw on battery and it always shows 0% battery used. Geofencing works flawlessly.
I use Tailscale for my Jellyfin instance and it was a breese to give (and remove) access to friends and family. Just sharing a link with them and that’s it.
If you use Home Assistant OS, the official Tailscale Add-On is well maintained and works flawlessly (provided your hardware can support it).
It’s more work and configuration than to simply open a port on your router but to me, it’s totally worth it. I feel in control, I can install it in 3 minutes on any new device and it even handles SSL/TLS for me so I can use my domain name to access my ressources.
I would stay away from CloudFlare tunnel as it basically acts as a Man in the Middle. It can see all your traffic unencrypted and it used this in the past to ban users as streaming content is not allowed in their condition of use. Tailscale is peer-to-peer and even though they sometimes use relays when direct p2p is not possible, they never see your traffic.
Lastly, you can use it as a VPN for internet browsing by installing it on a VM running any public VPN client (e.g. ProtonVPN) and using that node as an exit-node.
Hope this helped.
I have a CF tunnel, I am not happy with it, I hate to get notifications of users trying to login since it’s a public domain. I also have a zero tier connection to get into my jellyfin remotely but I don’t like that I get a different IP when I’m in zero tier. I think your solution is just optimized, can you point me out into how to make it work? How does your phone automatically connect into tail scale when out of home? Do you get to access your jellyfin with the same IP? I just hate to have to ips for my jellyfin, as if I had 2 servers
Since nobody mentioned this option: you can also use a small device that
already sits inside the LAN as the relay, instead of a tunnel client on
the machine you want to reach.
Full disclosure, this is my project — Sensmos. It’s an ESP32 that keeps an outbound connection, so no port forwarding, works fine behind CGNAT, and nothing gets exposed to the internet: the tunnel is owner-only, off by default, and hard-limited to RFC1918 addresses, so it physically cannot reach a public host. From the app you get an SSH terminal into the LAN, a Home Assistant panel,
To be fair about the tradeoff: if you only need the HA web UI in a
browser, Cloudflare Tunnel or Nabu Casa are simpler and I’d use those.
This makes sense when you want the whole LAN — router page, NAS, a shell —
without installing an agent on each target or running a full VPN
