I have setup home assistant on a raspberry pi 3b+, and added external acces through duckdns, the external acces works fine, but it says the external acces is disabled:
This causes this error as well:
Home Assistant detected that SSL has been set up on your instance, however, no custom external internet URL has been set.
This may result in unexpected behavior. Text-to-speech may fail, and integrations may not be able to connect back to your instance correctly.
To address this issue, go to Settings > System > Network; under the “Home Assistant URL” section, configure your new “Internet” and “Local network” addresses that match your new SSL configuration.
however, under network I dont see URL options.
besides that my google home sometimes has trouble reaching the home assistant, i wonder if that is because of the same issue?
