This will be my first post, so please bear with me . I have discovered the Home Assistant community only a couple of weeks ago and I decided on the container install method because it is a little work related and new learning opportunity. A lot to unpack to say the least. I got things up and running already with the exception of the remote access, at least partially.
Here is my situation: I have a DDNS provided by my ISP that provides me with a domain, and only that, no access token, I have asked, and I have a NGINX webserver that is already acting as a homepage for my other services that I have running: Sonarr, Radarr etc. NGINX config has been done by a friend of mine, so I have very little knowhow with it. All is know that ports 80 and 443 are already pointing to it.
I want to put the access to Home Assistant behind the same webserver, I read that it does not support using a path External_URL
I have remote access if I forward port 8123, but it is unsecured.
I have a couple of the guides here in the community, but it didn’t help me very much with my situation, I admit there are a lot of things that I am unaware of.
Any kind of help would be greatly appreciated. And if other info is required.
Thank you!
This is my running NGINX config.
# You should look at the following URL's in order to grasp a solid understanding
# of Nginx configuration files in order to fully unleash the power of Nginx.
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
# Please see /usr/share/doc/nginx-doc/examples/ for more detailed examples.
# Default server configuration
server {
listen 80 default_server;
listen [::]:80 default_server;
# SSL configuration
# listen 443 ssl default_server;
# listen [::]:443 ssl default_server;
# Note: You should disable gzip for SSL traffic.
# See: https://bugs.debian.org/773332
# Read up on ssl_ciphers to ensure a secure configuration.
# See: https://bugs.debian.org/765782
# Self signed certs generated by the ssl-cert package
# Don't use them in a production server!
# include snippets/snakeoil.conf;
root /var/www/html;
# Add index.php to the list if you are using PHP
index index.html index.htm index.nginx-debian.html;
server_name _;
location / {
# First attempt to serve request as file, then
# as directory, then fall back to displaying a 404.
try_files $uri $uri/ =404;
# pass PHP scripts to FastCGI server
#location ~ \.php$ {
# include snippets/fastcgi-php.conf;
# # With php-fpm (or other unix sockets):
# fastcgi_pass unix:/run/php/php7.4-fpm.sock;
# # With php-cgi (or other tcp sockets):
# fastcgi_pass 127.0.0.1:9000;
# deny access to .htaccess files, if Apache's document root
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
# Virtual Host configuration for example.com
# You can move that to a different file under sites-available/ and symlink that
# to sites-enabled/ to enable it.
#server {
# listen 80;
# listen [::]:80;
# server_name example.com;
# root /var/www/example.com;
# index index.html;
# location / {
# try_files $uri $uri/ =404;
server {
# SSL configuration
root /var/www/html;
server_name mydomain; # managed by Certbot
location /sonarr {
proxy_pass http://localhost:8989/sonarr;
location /radarr {
proxy_pass http://localhost:7878/radarr;
location /readarr {
proxy_pass http://localhost:8787/readarr;
location /lidarr {
proxy_pass http://localhost:8686/lidarr;
location /prowlarr {
proxy_pass http://localhost:9696/prowlarr;
location ^~ /overseerr {
set $app 'overseerr';
rewrite ^/overseerr/?(.*)$ /$1 break;
proxy_pass http://localhost:5055;
# Redirect location headers
proxy_redirect ^ /$app;
proxy_redirect /setup /$app/setup;
proxy_redirect /login /$app/login;
# Sub filters to replace hardcoded paths
proxy_set_header Accept-Encoding "";
sub_filter_once off;
sub_filter_types *;
sub_filter 'href="/"' 'href="/$app"';
sub_filter 'href="/login"' 'href="/$app/login"';
sub_filter 'href:"/"' 'href:"/$app"';
sub_filter '\/_next' '\/$app\/_next';
sub_filter '/_next' '/$app/_next';
sub_filter '/api/v1' '/$app/api/v1';
sub_filter '/login/plex/loading' '/$app/login/plex/loading';
sub_filter '/images/' '/$app/images/';
sub_filter '/android-' '/$app/android-';
sub_filter '/apple-' '/$app/apple-';
sub_filter '/favicon' '/$app/favicon';
sub_filter '/logo_' '/$app/logo_';
sub_filter '/site.webmanifest' '/$app/site.webmanifest';
location /deluge {
proxy_pass http://localhost:8112/;
proxy_set_header X-Deluge-Base "/deluge/";
add_header X-Frame-Options SAMEORIGIN;
# location / {
#sub_filter 'src=/static/' 'src=/haas/static/';
#sub_filter 'src=/hacs-files/' 'src=/haas/hacs-files/';
#sub_filter_once off;
# proxy_pass http://127.0.0.1:8123;
# proxy_pass http://localhost:8123/lovelace/0;
# proxy_set_header Host $host;
# proxy_redirect http:// https://;
# proxy_http_version 1.1;
# proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
# proxy_set_header Upgrade $http_upgrade;
# proxy_set_header Connection "upgrade";
#location ~ /\.ht {
# deny all;
listen [::]:443 ssl ipv6only=on; # managed by Certbot
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/mydomain/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/mydomain/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
if ($host = mydomain) {
return 301 https://$host$request_uri;
} # managed by Certbot
listen 80 ;
listen [::]:80 ;
return 404; # managed by Certbot
Docker compose config
version: '3'
services:
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:stable"
volumes:
- /opt/hass:/config
- /etc/localtime:/etc/localtime:ro
- /run/dbus:/run/dbus:ro
restart: unless-stopped
privileged: true
network_mode: host
