Hello Home Assistant Community,
I am facing an issue with remote access to my CCTV video feeds in Home Assistant and could use some guidance to resolve it. Here’s a brief overview of my setup:
NVR Setup: I have connected my NVR device to a separate router without internet access because the NVR uses a P2P protocol to communicate with clients. Filtering specific ports is not feasible due to the P2P protocol’s nature, and my primary router lacks advanced settings beyond port forwarding.
Home Assistant Connection: The NVR router is connected to my Home Assistant server, and the Home Assistant server is linked to my home local area network. I have configured port forwarding on my primary internet router to allow remote access to my
Home Assistant server. -
CCTV RTSP Links: I have obtained the CCTV RTSP links from the NVR router’s IP address and successfully added them to the Home Assistant dashboard.
Problem: While I can view the CCTV video feeds on my local server, I am unable to access the feeds when remotely accessing Home Assistant from outside my local network. The video streams are unavailable in the dashboard.
My primery router: 192.168.8.119
Secoundary router: 192.168.1.6
Stream when local area network (upload://pIcfZ3Mb7mxBz6YvBtEVGVlZShk.jpeg)
When accessing through remort access (upload://xDRhV8i5Cbr6C6MwWKITdQLvZ0L.png)
Thank you for your support and assistance.
