Hi everyone, I hope you can help me.
I’m currently experiencing a problem with remote access through Home Assistant Cloud (Nabu Casa). In Settings > Home Assistant Cloud, the remote access switch is turned on, and the remote URL is properly displayed (https://xxxxx.ui.nabu.casa).
The issue is:
When I’m connected to my home WiFi network, I can access Home Assistant through the Nabu Casa URL with no issues.
However, when I disconnect from my WiFi (using mobile data or connecting from an external network), remote access does not work. I get an error saying it’s unable to connect to Home Assistant.
What I’ve already tried:
Turning remote access off and on again.
Signing out from Home Assistant Cloud and signing back in.
Restarting Home Assistant and my router.
Confirmed that Home Assistant is working fine locally using the local IP (http://local-ip:8123).
My ISP is Izzi (Mexico), in case that’s relevant.
I would appreciate any help from someone who may have experienced this issue or has any suggestions to solve it.
Thanks in advance!
