Hi there.
I used this video to successfully set up remote access via Cloudflare and have been using it perfectly for quite some time, now.
However, I have just upgraded my system from OS to Container and suddenly realised that the Cloudflare method no longer works.
Is there a commonly recommended method to still have remote access, please, that can sill be used with a Container installation?
GlennHA
(Glenn)
April 26, 2023, 8:14pm
2
look at “SWAG” from LinuxServer.io on Docker Hub that will get you your reverse proxy and Let’s Encrypt
Tinkerer
(aka DubhAd on GitHub)
April 26, 2023, 8:38pm
3
Traefik is easy and works really well, plus it has support for LetsEncrypt.
You can also continue using Cloudflare. Just add the following to your compose file:
cloudflared:
container_name: cloudflared
image: cloudflare/cloudflared
restart: unless-stopped
command: tunnel run
env_file: cloudflared.env
cloudflared.env
contains your token, like:
TUNNEL_TOKEN=blahblahblah
Then just configure tunnel as before.
Thanks guys - much appreciated.
Networking, in particular, is still a bit of mystery to me - especially now I am using containers, which seems to add an extra layer of complication.
I think I shall get Cloudflare up and running and I can always migrate to something else (as mentioned), once I have learnt a bit more.
May I just double check something, please -
If I run the following container:
cloudflared:
command: tunnel run
How does that get linked to Home Assistant?
I get how it does, when the HA Cloudflare add-on, is used but the above does not seem to have any specific link to HA.
Tinkerer
April 27, 2023, 12:34pm
5
That’s done at the Cloudflare end:
Thanks Tinkerer - I think I am starting to understand how this all fits together.
As I previously followed that video, when I had a previous OS installation, I logged back into my Cloudflare account. I managed to find a page called API Tokens.
Two keys are there, viewable by password - one of these is Global API Key and the other is Origin CA Key. Which of these, if either, is the TUNNEL_TOKEN above?
Tinkerer
April 28, 2023, 6:45am
7
Look at the Tunnel configuration page, under Overview, you’ll find the token under Install and run connector :
Run the following command:
$ cloudflared.exe service install TOKEN_HERE
