I switched routers, from UniFi to OPNSense and now I’m having issues accessing my HomeAssistant server remotely. I’m struggling to work out why it’s not working.
I have HomeAssistant running with DuckDNS addon.
I’ve setup NAT Port Forwarding in OPNsense. Forwarding 8123 and 443 from WAN to to the local IP of the HomeAssistant server on port 8123.
I’ve checked on https://canyouseeme.org/ that both 443 and 8123 show as open.
Port Forwarding looks like it’s working correctly.
I can access HA on my local IP on the :8123 port over HTTPS. I obvs, get an SSL cert warning.
I’ve also checked DuckDNS, which is showing the correct IP for my domain name. And when I use a nslookup the DuckDNS name resolves to the correct public IP address. I also tried a port scanner with domain name resolution, using that to scan the DuckDNS domain name on ports 8123 and 443. It shows both as open.
When I try to access the duckdns URL xxxxx.duckdns.org:8123 or :443, I get a HomeAssistant logo and spinnning / Loading Data. But nothing ever happens. It’ll then turn to the Unable to connect to Home Assistant...
It looks like DuckDNS addon in HomeAssistant is managing to correctly connect and issue new SSL certs via LetsEncrypt.
What else can I try or where can I look to try and find out what’s going wrong? I’m stumped.
DuckDNS Addon Log
My DuckDNS Log
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
# INFO: Using main config file /data/workdir/config
+ Account already registered!
[08:08:23] INFO: Renew certificate for domains: xxxxxxxxx.duckdns.org and aliases:
Processing xxxxxxxxx.duckdns.org
+ Checking domain name(s) of existing cert... unchanged.
+ Checking expire date of existing cert...
+ Valid till Aug 10 01:43:05 2024 GMT (Longer than 30 days). Skipping renew!
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
+ Generating account key...
+ Registering account key with ACME server...
+ Fetching account URL...
+ Done!
[08:21:34] INFO: Renew certificate for domains: xxxxxxxxx.duckdns.org and aliases:
+ Creating chain cache directory /data/workdir/chains
+ Creating new directory /data/letsencrypt/xxxxxxxxx.duckdns.org ...
+ Signing domains...
+ Generating private key...
+ Generating signing request...
+ Requesting new certificate order from CA...
+ Received 1 authorizations URLs from the CA
+ Handling authorization for xxxxxxxxx.duckdns.org
+ 1 pending challenge(s)
+ Deploying challenge tokens...
OK + Responding to challenge for xxxxxxxxx.duckdns.org authorization...
+ Challenge is valid!
+ Cleaning challenge tokens...
OK + Requesting certificate...
+ Checking certificate...
+ Done!
+ Creating fullchain.pem...
+ Done!
[10:35:25] INFO: Renew certificate for domains: xxxxxxxxx.duckdns.org and aliases:
+ Valid till Aug 19 06:21:41 2024 GMT (Longer than 30 days). Skipping renew!
[10:46:14] INFO: Renew certificate for domains: xxxxxxxxx.duckdns.org and aliases:
additional info
I can access HomeAssistant remotely from my phones cellular. The issue seems to be restricted to access it remotely via the DuckDNS url from within my LAN.
