I setup a dns remote access tunnel to my Raspberry Pi running Home Assistant. When I’m on my home network, I can access my esp32 running its own web server DIRECTLY. Remotely, I can go through Home Assistant and use my esp32 in an automation, but I want to access the web page my esp makes Remotely. Anyone know tge best way to do this?
You might want to explain your exact setup in more detail. ![]()
By the looks of it your remote access is limited to the HA server and the rest of your network isn’t exposed - hence you can’t access any other machine than HA itself ![]()
That’s very relative. Depending on your needs and possibilities. For example if your router can handle wireguard vpn that could be a good way of accessing your local are network ![]()
a " dns remote access tunnel"
i don’t know what is that.
maybe you own a domain, then you add its record to a public dns server, and made a vpn tunel to your server ?
without vpn:
- You can’t embed sites using HTTP if you are using HTTPS for your Home Assistant.
- setup a reverse proxy to direct acces your esp32 http with https
or - open port in the router to use directly http://ip (poor security)
with vpn:
it 's should be as a local connection .
