Accessing remotely my HA via Duckdns and NGINX. After the recent update I am getting the error:
“400: Bad Request”
Restarted and checked both Duckdns and NGINX services. Both logs look fine. What am I missing?
“400: Bad Request”
From what version to what version?
“Recent” isn’t a version.
Most likely the very first breaking change here: 2021.7: A new entity, trigger IDs and script debugging - Home Assistant
If you are using Nginx for reverse proxy, you will need to add the following line in your configuration.yaml-
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24 # Add the IP address of the proxy
For the IP address, you should have an error logs (Configuration —> Logs) regarding reverse proxy. This should contain the IP address that you need to put inside the above code.
Note: if you are using Nginx add on, you can just use 172.30.33.0/24
which is the internal docker IP address range used by Home Assistant addon.
