(Sorry for the underscores, but the editor is interpreting part of my text as links for some reason. I am a new user so i cannot post more then 2 links)
I have installed Hassio on my Raspberry Pi 3B following the instructions for alternative install on a generic Linux host.
Everything works fine from my local network on 192.168.1.80:8123, but I am struggling to access HA remotely from my phone browser or HA app.
Notes:
- I have a static IP address
- I have a registered domain mysite_com
- I use Apache2 as reverse proxy on home_mysite.com (this redirects to the local HA on 8123)
- I have automatic redirection from http to https
- All my other services work as expected
- I have lets encrypt certificates for the all my subdomains including home_mysite_com
- I have copied the fullchain.pem and privkey.pem from the default letsencypt location to /usr/share/hassio/ssl
When I try to connect to home_mysite.com the following happens…
From the HA app (on 4G)
I get to the login phase, but when I click connect I receive a 405 error.
From the phone browser (on 4G)
I attempt to login but then I receive: Unable to connect to Home Assistant
From my browser (internal network)
Same as phone browser
If it helps, these are my settings.
https://www.dropbox.com/s/g3i98mr3r0glj1t/settings.txt?dl=0
And this is the log error message
020-02-08 09:50:42 ERROR (MainThread) [homeassistant.components.hassio] Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/usr/share/hassio/ssl/fullchain.pem'
not a file for dictionary value @ data['http']['ssl_key']. Got '/usr/share/hassio/ssl/privkey.pem'. (See /config/configuration.yaml, line 6).
Any suggestion?
