Remote access using swag not working
hello
i am trying to setup swag to use as remote access for home assistant and other docker containers, and cannot get past the swag welcome page. any suggestions on how i could fix this would be appreciated.
thanks!
my docker-compose
services:
  portainer:
    container_name: portainer
    image: portainer/portainer-ce
    restart: always
    ports:
      - "9000:9000/tcp"
    environment:
      - TZ=America/Chicago
    volumes:
      - /var/run/docker.sock:/var/run/docker.sock
      - /opt/portainer:/data
  swag:
    container_name: swag
    image: lscr.io/linuxserver/swag
    cap_add:
      - NET_ADMIN
    environment:
      - PUID=1000
      - PGID=1000
      - TZ=American/Chicago
      - URL=<subdomain>.duckdns.org
      - SUBDOMAINS=wildcard
      - VALIDATION=duckdns
      - DUCKDNSTOKEN=<token>
    volumes:
      - /opt/swag/config:/config
    ports:
      - 444:443
    restart: unless-stopped
  homeassistant:
    container_name: homeassistant
    image: "ghcr.io/home-assistant/home-assistant:stable"
    volumes:
      - /opt/homeassistant/config:/config
      - /etc/localtime:/etc/localtime:ro
    network_mode: swag
    ports:
      - 8123:8123
    privileged: true
i have created a user-defined bridge as swag for the home assistant and the other containers to connect to
my homeassistant.>subdomain<.conf
## Version 2023/02/05
# make sure that your homeassistant container is named homeassistant
# make sure that your dns has a cname set for homeassistant
# As of homeassistant 2021.7.0, it is now required to define the network range your proxy resides in, this is done in Homeassitants configuration.yaml
# https://www.home-assistant.io/integrations/http/#trusted_proxies
# Example below uses the default dockernetwork ranges, you may need to update this if you dont use defaults.
# http:
#   use_x_forwarded_for: true
#   trusted_proxies:
#     - 172.16.0.0/12
server {
    listen 443 ssl;
    listen [::]:443 ssl;
    server_name homeassistant.<subdomain>.duckdns.org;
    include /config/nginx/ssl.conf;
    client_max_body_size 0;
    # enable for ldap auth (requires ldap-location.conf in the location block)
    #include /config/nginx/ldap-server.conf;
    # enable for Authelia (requires authelia-location.conf in the location block)
    #include /config/nginx/authelia-server.conf;
    # enable for Authentik (requires authentik-location.conf in the location block)
    #include /config/nginx/authentik-server.conf;
    location / {
        enable the next two lines for http auth
        auth_basic "Restricted";
        auth_basic_user_file /config/nginx/.htpasswd;
        # enable for ldap auth (requires ldap-server.conf in the server block)
        #include /config/nginx/ldap-location.conf;
        # enable for Authelia (requires authelia-server.conf in the server block)
        #include /config/nginx/authelia-location.conf;
        # enable for Authentik (requires authentik-server.conf in the server block)
        #include /config/nginx/authentik-location.conf;
        include /config/nginx/proxy.conf;
        include /config/nginx/resolver.conf;
        set $upstream_app 192.168.XX.XXX;
        set $upstream_port 8123;
        set $upstream_proto http;
        proxy_pass $upstream_proto://$upstream_app:$upstream_port;
    location ~ ^/(api|local|media)/ {
home assistant configuration.yaml
http:
  ip_ban_enabled: true
  login_attempts_threshold: 3
  trusted_proxies:
    - 192.168.XX.0/24
    - 172.10.0.0/24
duckdns:
  domain: <subdomain>.duckdns.org
  access_token: <token>
Heres my config Reverse proxy using NGINX - #74 by SgtBatten
i tried your homeasssistant.subdomain.conf and am still getting the swag welcome page
I’m not familiar with duck DNS. Can you use subdomains when you already have a subdomain as your personal identifier?
yes, at least according to the several guides i’ve read
What does your main server block look like?
this has all been unchanged from the default swag setup
## Version 2023/04/13 - Changelog: https://github.com/linuxserver/docker-swag/commits/master/root/defaults/nginx/site-confs/default.conf.sample
# redirect all traffic to https
server {
    listen 80 default_server;
    listen [::]:80 default_server;
    location / {
        return 301 https://$host$request_uri;
# main server block
server {
    listen 443 ssl http2 default_server;
    listen [::]:443 ssl http2 default_server;
    server_name _;
    root /config/www;
    index index.html index.htm index.php;
    # enable subfolder method reverse proxy confs
    include /config/nginx/proxy-confs/*.subfolder.conf;
    location / {
        # enable for basic auth
        #auth_basic "Restricted";
        #auth_basic_user_file /config/nginx/.htpasswd;
        try_files $uri $uri/ /index.html /index.php$is_args$args =404;
    location ~ ^(.+\.php)(.*)$ {
        fastcgi_split_path_info ^(.+\.php)(.*)$;
        fastcgi_pass 127.0.0.1:9000;
        fastcgi_index index.php;
        include /etc/nginx/fastcgi_params;
    # deny access to .htaccess/.htpasswd files
    location ~ /\.ht {
        deny all;
# enable subdomain method reverse proxy confs
include /config/nginx/proxy-confs/*.subdomain.conf;
# enable proxy cache for auth
proxy_cache_path cache/ keys_zone=auth_cache:10m;
The file name needs to literally say subdomain to get included. If you changed it, change it back.
Hi how you dit it? Same trouble here. Cannot open homarr.domain.com. Working only with 10.0.100.5:7575. Used the subdomain.conf and just changed the adress. For others app its working not for this one.
