This is an “extension” of the builtin command_line
integration.
Besides the functionalities of the hereabove, it also:
- allow to disable polling altogether, relying on
homeassistant.update_entity
to trigger updates of the sensors - helps for remote connections via SSH
Additionally, it implements the functionalities of the shell_command
service, with the added capability to specify a timeout value.
The integration is configured via YAML only.
Examples:
- platform: remote_command_line
name: HA image version
scan_interval:
days: 1
ssh_user: user
command: >
IMAGE=`docker inspect home-assistant | jq -r '.[0].Config.Image'`; docker image inspect ${IMAGE} | jq -r '.[0].ContainerConfig.Labels["io.hass.version"]'
name: Fetch HA Image
ssh_user: user
command_timeout: 900
polling: false
command: >
IMAGE=`docker inspect home-assistant | jq -r '.[0].Config.Image'`; docker pull -q ${IMAGE} > /dev/null
Example of service:
remote_command_line:
fetch_ha_image:
ssh_user: user
command: >
See GitHub - koying/ha-remote-command-line: HA: Remote version of command_line (SSH) for more
