Hi guys,
I’m relatively new to HomeAssistant and sadly I can’t get my remote Access to work. I’ve tryed to use WireGuard VPN + DuckDNS, but it keep telling me that handschake is not completed on my phone logs. I’m getting really frustrated and I spend hours searching the web for a different tutorials on how to do it properly, but whatever I tried I can’t get it to work…
I didn’t change a lot in the config. I just had to change the dns to use my AdGuard as dns.
My wireguard config looks like this:
host: mydomain.duckdns.org
addresses:
- 172.27.66.1
dns:
- 172.30.32.1
peers:
- name: hassio
addresses:
- 172.27.66.2
allowed_ips: []
client_allowed_ips: []
My DuckDNS config:
domains:
- mydomain.duckdns.org
token: mytoken
aliases: []
lets_encrypt:
accept_terms: true
algo: secp384r1
certfile: fullchain.pem
keyfile: privkey.pem
seconds: 300
I’ve added this to my configuration.yaml
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
Also I defined this as my external address
https://mydomain.duckdns.org:51820
I’m using a FritzBox 6660 Cable and configured the portforward on port 51820 for my homeassistant
And also I activated dyndns in my FritzBox using the instruction on the duckdns site.
I really need help with this topic and I greatly appreciate every one of you!
