Remote Control for LED Stripes (RF 2501)
for a LED stripe I have a remote control with RF 2501 (868 Mhz).
Is there a way to become this LED stripe smart in Home Assistant?
Technical data (german)
Which receiver it has?
grafik
Probably easiest way would be Esphome devboard to control push switch contact.
Actual I have an ESP WT32 with CC1101 Modul (315/433/868/915MHz) ready here.
But how can I modify the software to control the push contact?
If you already have setup for controlling RF 868, try with that. CC1101 is not the easiest transceiver with esp32 though.
ps. What’s Esp WT32?
WT32-ETH01 Embedded Serial Port Networking Bluetooth
Which code do I need for controlling?
How are your skills, electronics / coding?
I use an other ESP to control my blinds, but the hardware-setup and code I found it on Github.
You didn’t answer my question…
that means, I able to config but not create a code from scratch
Still not clear…
You want to experiment with your weird board and cc1101 receiving and transmitting code? Not a beginner task.
If you know electronics and you have multimeter, you can connect your Esp to push button connector, with or without additional components.
If you want easy way, buy Shelly Plus1 and connect in/out to your receiver push switch contacts.
