Remote control rs485 rtu wired wi fi for heat pump
Good morning, I have installed a Ferroli Omnia 3.2 heat pump, in turn equipped with a wired remote control with RS485 btu connection, and wi-fi connected to the router, reachable via app presumably on a remote cloud. I wanted to read the registers of the machine through HA, as there is no integration for my case, reflection of pecking through the IP address assigned to it by the router with its dedicated port 502 for modbus the various readings, but I tried these 2 lines of
modbus code : name: hub1
type: tpc host: 192.168.1.102
port: 502
sensor_rails: name: “ferr 1”
address: 40001
scan_interval: 20 slave: 1
sensors: name: "Ferr 2
" unit_of_measurement: hz
scale: 0.1 slave: 0
accuracy: 2
input_type: input address: 40102
scan_interval: 30
but without getting results. Perhaps someone has already carried out this test or can give me some advice. Thank you
you solved ??
Hi , yes yes solved , although I had to implement with node red the reading of the registers , in HA I have some problem when I follow the guide for the modbus , it fails to create the entity . Now I’ve finished the slave part programmed in arduino, and then connect everything to the raspberry and join everything
HI
Hi Minixium, do you have a list of the registers of the Omnia 3.2? I am trying to connect also from HA, or Homey, to the Ferroli via Modbus, but I can’t find any info regarding the protocol or registers that they are using.
If you have any info you like to share it would be great, thanks in advance. :slight_smile:
also I have an Omnia Ferroli with Modbus.
On manual of wired remote control I’ve found a lot of modbus address, I can post later, hope to help someone to connect this HVAC to homeassistant
Hi, antonioste,
I’d be interested in the addresses you’ve found and where exactly have you found them.
All, you can find the Modbus table for the Ferroli here:
https://sgfm.elcorteingles.es/SGFM/dctm/MEDIA03/202309/22/00104790201836____3_.pdf
The table is in English, At the end wired controller manual from page 40 till 52
It is working, I can control the Ferroli, change Climate Curves, read out the internal temperatures and speed, switch bits in the controller on or off, but for some reason I can’t change \ readout some values of the Modbus. e.g. 261, 262, 263 … the parameters for the 9th climate curve.
anybody an idea why this is not possible??
Thanks ! :slight_smile:
Thank you!
I have a split one, so I haven’t thought about checking the monoblock version. The split model manual does not have any word about Modbus mapping while the monoblock has :man_shrugging:t2:
Gradually will try to integrate it. If I will resolve the curve 9 readout, will let you know.
Hello. Could you please share any of the modules that you built for this heat pump? It would be amazing for our community. I’ll have this pump in a few months :slight_smile: Then might also contribute! Thanks a lot
Can you share the .pdf in another way (if you are still around) ? This link says I have no permission for access
Currently it was developed an integration for this: omnia/omnia.py at f31df90b65b7c8a25524a188fde9b544f730eb26 · wowtor/omnia · GitHub
Hello! Can you post your solution found?
Many thanks!
Hello! I have also a split version Omnia S3.2. Have you done the integration? If yes, can you give me a copy of configuration file or code. Many thanks!
Hello! have you done the integration Ferroli Omnia S3.2 into HomeAssistant?
How did you connect the boiler to the mod bus while also leaving the remote control,I have a modbus to lan converter but it gives me a lot of problems
Hi, omnia ST here, where you able to do it? I have a lilygo and the yaml but there is no answer from the Omnia, I’m wondering if I should connect it somewhere inside instead of the ABE port close to the display, or if I’m missing any other thing. Already thinking about giving up…
