However… I am not able to connect remotely to the Rasberry Pi from my Windows 7 machine anymore, which was working fine before. The Rasberry itself only gives me the Home Assistant logo, so I can’t do anything there directly either. Is this supposed to be? Is it possible to still use the Rasberry Pi for other things when using Hass.io?
I have the same question… Anyone have a solution. I need to install one wire config and have not found a solution.
Cant use putty
Can’t modify the “/boot/config.txt”
Tried to plug in a monitor and keyboard and all i see is the Homeassistant home image
i tried SSH i can get in as root, you cant install or modify any config files…
from Doc “This add-on will not enable you to install packages or do anything as root. This is not allowed with Hass.io.”
It also appears you cannot hook a monitor and keyboard up to the Raspberry PI (3) and bring up the desktop.
I managed to get in and modify the “config” file by popping out the card and modifying it in file explorer on my PC.
Soo… For now im good. (was trying to get my 8, 1 wire sensors to work)
