is it possible to use remote/git packages as a template, so that you can customize variables in the template e.g. via substitution. So that the template can be used multiple times?
Since the following configuration unfortunately does not work, it does not seem to work as with the local !include via vars:.
Is there a solution for this requirement?
# Remote template configuration snippet
packages:
pm1: #Remote template XY, config 1
url: https://github.com/...
ref: main # optional
files:
- base.yaml
vars:
modbus_id: modbus_controller_1
pm2: #Remote template XY, config 2
files:
- base.yaml
vars:
modbus_id: modbus_controller_2
#Remote template XY
- platform: modbus_controller
modbus_controller_id: ${modbus_id}
address: 0x0034
register_type: read
value_type: FP32
accuracy_decimals: 3
unit_of_measurement: "W"
device_class: "power"
state_class: "measurement"
