Hi all
I have Pi4 as my Home Assistant server. This is the control for a remote pi3 that is controlling a mushroom fruiting room with a fan and humidifier.
All is working fine, there is a BME680 sensor that reads humidity, temperature, pressure and VOC content. There are two remote GPIO switches that switch the
humidifier and fan on.
My problem is the automation doesn’t work. I can trigger the action manually but it doesn’t seem to read the change in sensor data.
Here is my /config/configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# sensors on remote pi
- platform: mqtt
state_topic: 'bme680-temperature'
unit_of_measurement: '°C'
- platform: mqtt
state_topic: 'bme680-humidity'
unit_of_measurement: '%'
- platform: mqtt
state_topic: 'bme680-pressure'
unit_of_measurement: 'hPa'
- platform: mqtt
state_topic: 'bme680-air_qual'
# Switches on remote pi
switch:
- platform: remote_rpi_gpio
host: 192.168.86.178
ports:
12: Fan
ports:
11: Humidifier
And my automations:
- id: '1618905019905'
alias: Fan control above 26
description: Triggers fan above 26
- platform: numeric_state
entity_id: sensor.bme680_temperature
above: '26'
condition:
- condition: state
entity_id: switch.fan
state: 'Off'
- service: switch.turn_on
mode: single
- id: '1618905138664'
alias: Fan control below 26 (Duplicate)
below: '25'
for: 00:00:10
condition:
- condition: state
state: 'On'
- service: switch.turn_off
mode: single
Any help much appreciated!
I do get a check configuration error but this seems unrelated:
Invalid config for [group]: Entity ID sensor.bme680-temperature is an invalid entity ID for dictionary value @ data['group']['BME680']['entities']. Got ['sensor.bme680-temperature', 'sensor.bme680-humidity', 'sensor.bme680-pressure', 'sensor.bme680-air_qual']. (See /config/configuration.yaml, line 8).
