I have a remote home assistant at my company location. Here I have a 3D printer and a camera pointed at that 3D printer. That camera is configured as a generic RTSP camera in the home assistant at the remote location.
However I’d like to include this camera inside my home assistant at home.
I think this might be possible using REST API & a long lived token but I’m not sure how exactly to do t his for cameras.
I have already tested this with a simple sensor but a camera seems more complicated
Did you manage to get that work? I have setup of 2 HA’s; one in “main” and one in “remote”. I am using Remote Home Assistant.
On remote, I have cameras integrated and locally they are visible. On main, I can see camera entities prefixed etc. nicely, but no image from remote. All the other entities work as fine.
Hi, not really… The closest I got back then was creating a script that pulled one image off the camera instance of the other HA using bash and calling that script with ha shell command. This created a jpeg which I could display in HA. I made an automation calling that shell command every second… Making ideally a one fps camera but it was more like a 0.2 fps Camara … So long story short… No .
Maybe since then something has been added to accommodate our crazy needs
