Remote Home Assistant - 'NoneType' object is not subscriptable
I am getting the following error when I try to setup the remote node:
Logger: aiohttp.server
Source: data_entry_flow.py:333
First occurred: 4:03:13 PM (1 occurrences)
Last logged: 4:03:13 PM
Error handling request
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
    resp = await self._request_handler(request)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 499, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 98, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 24, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 138, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 135, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 192, in post
    return await super().post(request)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 62, in wrapper
    result = await method(view, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 71, in post
    result = await self._flow_mgr.async_init(
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 197, in async_init
    flow, result = await task
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 224, in _async_init
    result = await self._async_handle_step(flow, flow.init_step, data, init_done)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 333, in _async_handle_step
    if result["type"] not in (
TypeError: 'NoneType' object is not subscriptable
Using a Raspberry Pi B with Home Assistant Container on 2021.11.3 and Remote Home Assistant 3.6. Has anyone experienced this error before?
