Joe3
November 9, 2022, 9:07am
1
Each platform works with tested running code apart from each other.
When put both on one device the remote_receiver stops working and the only indication of this is,
[01:54:32][W][remote_receiver.esp8266:063]: Remote Receiver Signal starts with a HIGH value. Usually this means you have to invert the signal using 'inverted: True' in the pin schema!
again… both pieces of code work until put on the same device. I can take the max7219digit code out and then the remote_receiver starts to show rc_switch data on the logger.
Is this a bug in ESPhome?
esphome:
esp8266:
board: d1_mini
captive_portal:
remote_receiver:
pin:
number: D5
dump: rc_switch
tolerance: 50
filter: 4us
idle: 3ms
binary_sensor:
- platform: remote_receiver
rc_switch_raw:
code: '110100100001001000001010'
protocol: 2
filters:
delayed_off: 4s
spi:
clk_pin: D0
mosi_pin: D1
time:
- platform: homeassistant
font:
- file: 'pixelmix.ttf'
display:
- platform: max7219digit
cs_pin: D2
num_chips: 4
rotate_chip: 0
intensity: 0
scroll_enable: false
update_interval: 5s
lambda: |-
it.strftime(3, 0, id(digit_font8), "%I:%M", id(homeassistant_time).now());
Joe3
November 9, 2022, 9:15am
3
nickrout:
s that wo
I don’t get this warning when only the remote_receiver code is used.
It just works. e.g. receives RF and triggers the position sensor.
when I add the display code, remote_receiver stops working.
nickrout
(Nick Rout)
November 9, 2022, 9:17am
4
I asked if doing as the error message suggests fixes it.
esp32_ble_tracker can do something similar.
opened 03:29PM - 09 Jun 21 UTC
integration: esp32_ble_tracker
<!-- Thanks for reporting a bug for this project. READ THIS FIRST:
- Provide … as many details as possible. Simply saying "X gives bug" or "X gives error" is not enough!
- Paste logs, configuration sample and code into the backticks (```).
- Read through the template carefully and fill out all missing details.
- Please also search for similar issues in this issue tracker first and read through the ESPHome FAQ.
DO NOT DELETE ANY TEXT from this template! Otherwise the issue may be closed without a comment.
**Operating environment/Installation (Hass.io/Docker/pip/etc.):**
Please provide details about your environment below this line. -->
pip
**ESP (ESP32/ESP8266, Board/Sonoff):**
Please provide details about which ESP you're using below.
ESP32
**ESPHome version (latest production, beta, dev branch)**
ESPHome version like v1.14 or 1.15-dev
1.18.0
**Affected component:**
Please add the link to the documentation at https://esphome.io/index.html of the component in question.
esp32_ble_tracker
https://esphome.io/components/esp32_ble_tracker.html
**Description of problem:**
When enabling `esp32_ble_tracker` in addition to some other components, the ESP becomes unstable and crashes/reboots constantly. Sometimes it never finishes booting and gets stuck in a boot loop. It appears to be reproducible ~ 8/10 times.
I've encountered this issue when combining `esp32_ble_tracker` with `web` and `fastled_clockless`, however it does not seem to be specific to any component other than `esp32_ble_tracker`
Running `esp32_ble_tracker` on its own with no other sensors enabled at the same time seems to be stable.
**Problem-relevant YAML-configuration entries:**
```yaml
esphome:
platform: ESP32
board: nodemcu-32s
logger:
logs:
esp32_ble_tracker: INFO
esp32_ble_tracker:
- platform: ble_rssi
mac_address: "A4:C1:38:XX:XX:XX"
name: "Kitchen BLE RSSI"
- platform: atc_mithermometer
temperature:
name: "Kitchen Temperature"
humidity:
name: "Kitchen Humidity"
battery_level:
name: "Kitchen LYWSD03MMC Battery Level"
battery_voltage:
name: "Kitchen LYWSD03MMC Battery Voltage"
name: "Bathroom BLE RSSI"
temperature:
name: "Bathroom Temperature"
humidity:
name: "Bathroom Humidity"
battery_level:
name: "Bathroom LYWSD03MMC Battery Level"
battery_voltage:
name: "Bathroom LYWSD03MMC Battery Voltage"
name: "Office BLE RSSI"
temperature:
name: "Office Temperature"
humidity:
name: "Office Humidity"
battery_level:
name: "Office LYWSD03MMC Battery Level"
battery_voltage:
name: "Office LYWSD03MMC Battery Voltage"
name: "Fridge BLE RSSI"
temperature:
unit_of_measurement: "°C"
name: "Fridge Temperature"
humidity:
name: "Fridge Humidity"
battery_level:
name: "Fridge LYWSD03MMC Battery Level"
battery_voltage:
name: "Fridge LYWSD03MMC Battery Voltage"
- platform: wifi_signal
name: ble-test WiFi Signal
update_interval: 60s
- platform: uptime
wifi:
power_save_mode: NONE
ap:
ssid: ble-test_AP
password: !secret 'hotspot_password'
networks:
- ssid: !secret 'wifi_name'
password: !secret 'wifi_password'
time:
api:
password: !secret 'ota_password'
ota:
web_server:
text_sensor:
- platform: version
light:
- platform: fastled_clockless
chipset: WS2812B
pin: 32
num_leds: 300
rgb_order: GRB
name: Kitchen LED Strip
restore_mode: ALWAYS_OFF
**Logs (if applicable):**
Please copy the debug log here. If possible, also connect to the ESP over USB and copy those logs into the backticks.
[08:11:46][I][logger:170]: Log initialized
[08:11:46][C][ota:366]: There have been 1 suspected unsuccessful boot attempts.
[08:11:46][I][app:029]: Running through setup()...
[08:11:46][C][fastled:010]: Setting up FastLED light...
[08:11:46][C][light:097]: Setting up light 'Kitchen LED Strip'...
[08:11:46][D][light:265]: 'Kitchen LED Strip' Setting:
[08:11:46][D][light:278]: Brightness: 100%
[08:11:46][D][light:287]: Red=100%, Green=100%, Blue=100%
[08:11:47][D][text_sensor:015]: 'ble-test_version': Sending state '1.18.0 Jun 9 2021, 07:58:34'
[08:11:47][C][wifi:033]: Setting up WiFi...
[08:11:47][D][wifi:324]: Starting scan...
[08:11:47][D][sensor:099]: 'ble-test_uptime': Sending state 0.80300 s with 0 decimals of accuracy
[08:11:49][D][wifi:339]: Found networks:
[08:11:49][I][wifi:385]: - 'Sprinkles' (D4:68:4D:XX:XX:XX) ▂▄▆█
[08:11:49][D][wifi:386]: Channel: 3
[08:11:49][D][wifi:387]: RSSI: -35 dB
<SNIP>
[08:11:49][I][wifi:194]: WiFi Connecting to 'Sprinkles'...
[08:11:50][D][sensor:099]: 'Fridge BLE RSSI': Sending state -79.00000 dB with 0 decimals of accuracy
[08:11:50][D][atc_mithermometer:116]: Got ATC MiThermometer (A4:C1:38:XX:XX:XX):
[08:11:50][D][atc_mithermometer:119]: Temperature: 3.3 °C
[08:11:50][D][atc_mithermometer:122]: Humidity: 21 %
[08:11:50][D][atc_mithermometer:125]: Battery Level: 71 %
[08:11:50][D][atc_mithermometer:128]: Battery Voltage: 2.846 V
[08:11:50][D][sensor:099]: 'Fridge Temperature': Sending state 3.30000 °C with 1 decimals of accuracy
[08:11:50][D][sensor:099]: 'Fridge Humidity': Sending state 21.00000 % with 0 decimals of accuracy
[08:11:50][D][sensor:099]: 'Fridge LYWSD03MMC Battery Level': Sending state 71.00000 % with 0 decimals of accuracy
[08:11:50][D][sensor:099]: 'Fridge LYWSD03MMC Battery Voltage': Sending state 2.84600 V with 3 decimals of accuracy
[08:11:51][I][wifi:457]: WiFi Connected!
[08:11:51][C][wifi:303]: SSID: 'Sprinkles'
[08:11:51][C][wifi:304]: IP Address: 192.168.2.177
[08:11:51][C][wifi:306]: BSSID: D4:68:4D:XX:XX:XX
[08:11:51][C][wifi:307]: Hostname: 'ble-test'
[08:11:51][C][wifi:311]: Signal strength: -36 dB ▂▄▆█
[08:11:51][C][wifi:315]: Channel: 3
[08:11:51][C][wifi:316]: Subnet: 255.255.255.0
[08:11:51][C][wifi:317]: Gateway: 192.168.2.1
[08:11:51][C][wifi:318]: DNS1: 192.168.2.1
[08:11:51][C][wifi:319]: DNS2: 0.0.0.0
[08:11:51][D][wifi:466]: Disabling AP...
[08:11:51][C][web_server:073]: Setting up web server...
[08:11:51][C][ota:029]: Over-The-Air Updates:
[08:11:51][C][ota:030]: Address: ble-test.local:3232
[08:11:51][C][ota:032]: Using Password.
[08:11:51][C][api:022]: Setting up Home Assistant API server...
[08:11:51][E][AsyncTCP.cpp:1296] begin(): _pcb == NULL
[08:11:51][I][app:059]: setup() finished successfully!
[08:11:51][D][sensor:099]: 'ble-test WiFi Signal': Sending state -36.00000 dBm with 0 decimals of accuracy
[08:11:51]abort() was called at PC 0x401d36c3 on core 1
[08:11:51]
[08:11:51]Backtrace: 0x40092630:0x3ffce680 0x40092861:0x3ffce6a0 0x401d36c3:0x3ffce6c0 0x401d370a:0x3ffce6e0 0x401d3025:0x3ffce700 0x401d30fc:0x3ffce720 0x401d2e71:0x3ffce740 0x400da011:0x3ffce760 0x400da05d:0x3ffce790 0x400da071:0x3ffce7b0 0x400da093:0x3ffce7d0 0x400d9eb9:0x3ffce7f0 0x400d9ee1:0x3ffce810 0x400da821:0x3ffce830 0x400da879:0x3ffce860 0x400dfb7b:0x3ffce890 0x400dfbc7:0x3ffce8d0 0x401f01c1:0x3ffce910 0x400de6bd:0x3ffce930 0x400de749:0x3ffce960 0x400de7ad:0x3ffce9c0 0x400e4271:0x3ffce9f0 0x400e4281:0x3ffcea10 0x401f00d9:0x3ffcea30 0x40081152:0x3ffcea50 0x400e43bd:0x3ffceaa0 0x400e6bfe:0x3ffcead0 0x400f4f15:0x3ffceaf0 0x4008ed79:0x3ffceb10
WARNING Found stack trace! Trying to decode it
WARNING Decoded 0x40092630: invoke_abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp32/panic.c:707
WARNING Decoded 0x40092861: abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp32/panic.c:707
WARNING Decoded 0x401d36c3: __cxxabiv1::__terminate(void (*)()) at /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libstdc++-v3/libsupc++/eh_terminate.cc:112
WARNING Decoded 0x401d370a: std::terminate() at /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libstdc++-v3/libsupc++/eh_terminate.cc:112
WARNING Decoded 0x401d3025: __cxa_allocate_exception at /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libstdc++-v3/libsupc++/eh_alloc.cc:313
WARNING Decoded 0x401d30fc: operator new(unsigned int) at /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libstdc++-v3/libsupc++/new_op.cc:54
WARNING Decoded 0x401d2e71: operator new[](unsigned int) at /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libstdc++-v3/libsupc++/new_opv.cc:32
WARNING Decoded 0x400da011: esphome::json::VectorJsonBuffer::reserve(unsigned int) at /home/lanrat/code/esphome/test/ble-test/.piolibdeps/ble-test/ArduinoJson-esphomelib/src/ArduinoJson/Deserialization/JsonParserImpl.hpp:166
WARNING Decoded 0x400da05d: esphome::json::VectorJsonBuffer::resize(unsigned int) at /home/lanrat/code/esphome/test/ble-test/.piolibdeps/ble-test/ArduinoJson-esphomelib/src/ArduinoJson/Deserialization/JsonParserImpl.hpp:166
WARNING Decoded 0x400da071: esphome::json::VectorJsonBuffer::do_alloc(unsigned int) at /home/lanrat/code/esphome/test/ble-test/.piolibdeps/ble-test/ArduinoJson-esphomelib/src/ArduinoJson/Deserialization/JsonParserImpl.hpp:166
WARNING Decoded 0x400da093: esphome::json::VectorJsonBuffer::alloc(unsigned int) at /home/lanrat/code/esphome/test/ble-test/.piolibdeps/ble-test/ArduinoJson-esphomelib/src/ArduinoJson/Deserialization/JsonParserImpl.hpp:166
WARNING Decoded 0x400d9eb9: ArduinoJson::Internals::JsonBufferAllocated::operator new(unsigned int, ArduinoJson::JsonBuffer*) at /home/lanrat/code/esphome/test/ble-test/.piolibdeps/ble-test/ArduinoJson-esphomelib/src/ArduinoJson/Deserialization/JsonParserImpl.hpp:166
WARNING Decoded 0x400d9ee1: ArduinoJson::JsonBuffer::createObject() at /home/lanrat/code/esphome/test/ble-test/.piolibdeps/ble-test/ArduinoJson-esphomelib/src/ArduinoJson/Deserialization/JsonParserImpl.hpp:166
WARNING Decoded 0x400da821: esphome::json::build_json(std::function<void (ArduinoJson::JsonObject&)> const&, unsigned int*) at /home/lanrat/code/esphome/test/ble-test/.piolibdeps/ble-test/ArduinoJson-esphomelib/src/ArduinoJson/Deserialization/JsonParserImpl.hpp:166
WARNING Decoded 0x400da879: esphome::json::build_json[abi:cxx11](std::function<void (ArduinoJson::JsonObject&)> const&) at /home/lanrat/code/esphome/test/ble-test/.piolibdeps/ble-test/ArduinoJson-esphomelib/src/ArduinoJson/Deserialization/JsonParserImpl.hpp:166
WARNING Decoded 0x400dfb7b: esphome::web_server::WebServer::sensor_json[abi:cxx11](esphome::sensor::Sensor*, float) at /home/lanrat/code/esphome/test/ble-test/src/esphome/components/web_server/web_server.cpp:68
WARNING Decoded 0x400dfbc7: esphome::web_server::WebServer::on_sensor_update(esphome::sensor::Sensor*, float) at /home/lanrat/code/esphome/test/ble-test/src/esphome/components/web_server/web_server.cpp:68
WARNING Decoded 0x401f01c1: std::_Function_handler<void (float), esphome::Controller::setup_controller()::{lambda(float)#2}>::_M_invoke(std::_Any_data const&, float&&) at /home/lanrat/code/esphome/test/ble-test/src/esphome/core/controller.cpp:29
(inlined by) _M_invoke at /home/lanrat/.platformio/packages/toolchain-xtensa32/xtensa-esp32-elf/include/c++/5.2.0/functional:1871
WARNING Decoded 0x400de6bd: std::function<void (float)>::operator()(float) const at /home/lanrat/code/esphome/test/ble-test/src/esphome/components/sensor/sensor.cpp:92
WARNING Decoded 0x400de749: esphome::CallbackManager<void (float)>::call(float) at /home/lanrat/code/esphome/test/ble-test/src/esphome/components/sensor/sensor.cpp:92
(inlined by) esphome::sensor::Sensor::internal_send_state_to_frontend(float) at /home/lanrat/code/esphome/test/ble-test/src/esphome/components/sensor/sensor.cpp:100
WARNING Decoded 0x400de7ad: esphome::sensor::Sensor::publish_state(float) at /home/lanrat/code/esphome/test/ble-test/src/esphome/components/sensor/sensor.cpp:92
WARNING Decoded 0x400e4271: esphome::wifi_signal::WiFiSignalSensor::update() at /home/lanrat/code/esphome/test/ble-test/src/esphome/components/wifi_signal/wifi_signal_sensor.h:13
WARNING Decoded 0x400e4281: non-virtual thunk to esphome::wifi_signal::WiFiSignalSensor::update()
WARNING Decoded 0x401f00d9: std::_Function_handler<void (), esphome::PollingComponent::call_setup()::{lambda()#1}>::_M_invoke(std::_Any_data const&) at /home/lanrat/code/esphome/test/ble-test/src/esphome/core/component.cpp:163
WARNING Decoded 0x40081152: std::function<void ()>::operator()() const at /home/lanrat/.platformio/packages/toolchain-xtensa32/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_vector.h:932
(inlined by) esphome::Scheduler::call() at /home/lanrat/code/esphome/test/ble-test/src/esphome/core/scheduler.cpp:158
WARNING Decoded 0x400e43bd: esphome::Application::loop() at /home/lanrat/code/esphome/test/ble-test/src/esphome/core/application.cpp:70
WARNING Decoded 0x400e6bfe: loop() at /home/lanrat/code/esphome/test/ble-test/src/esphome/components/light/light_output.h:18
WARNING Decoded 0x400f4f15: loopTask(void*) at /home/lanrat/.platformio/packages/framework-arduinoespressif32/cores/esp32/main.cpp:19
WARNING Decoded 0x4008ed79: vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port.c:355 (discriminator 1)
[08:11:52]
[08:11:52]Rebooting...
[08:11:52]ets Jul 29 2019 12:21:46
**Additional information and things you've tried:**
I've tried multiple different ESP32 boards and all seem to have the same behavior. I've also tried adding/removing different components and the only constant to reproduce this issue seems to be `esp32_ble_tracker`.
I would try a board with more resources and see if that helps. A decent ESP32.
I’m not saying it will fix it, but a key learning for me has been that ESP quality can matter.
What’s your favourite ESP32 board? Why?
Where do you buy from? Why?
What board features do you value the most?
I’m getting a bit sick of flakey cheap Ali Express knock-offs, so becoming more interested in higher quality boards (but don’t mind cheap ones for the basics).
I thought this topic might be worth a dedicated Home Assistant thread? Couldn’t see an existing one.
Joe3
November 12, 2022, 12:35am
9
Thnx, but I would bet it’s a ESPhome firmware issue… A log or report of these conflicts would be nice but it happily compiles and uploads just fine. add to wish list though.
Thanks for the suggestion
nickrout
(Nick Rout)
November 12, 2022, 4:30am
10
If you have found an error in esphome then post a GitHub issue.
Joe3
November 12, 2022, 8:23pm
11
I will … It’s just a pain. Was hoping I was doing something stupid.
Here’s some standard steps I go through before raising an issue (which takes time before someone else can look at it as well as taking thier time) :
Triple check all connections. Maybe even solder them.
Try different pins
Try a different board (I always have spares)
Try a different sensor (I typically have spares)
Try a different power source (good quality)
Try a different usb cable (if relevant, good quality).
I’m always amazed how often one of these simple things resolves my issue. And then if you raise an issue you also have a solid list of things you’ve tried, and so are more likely to get help.
Recently I was setting up an RF transmitter/receiver and it didn’t work properly on two ESP32s. I switched to a quinled and it started working flawlessly.
