Hi guys
I have a problem and i am going crazy… i will give you info on what I want to achieve but is not working and I need some help…
So i have Windows 10/ Plex server in my country but I live in Germany.
I have a HA in Germany that is running on proxmox. I want to monitor Windows servers with HA with open hardware info I found is easy. You have just installed OHM and Optins - remote web server and run and locally is working.
So what I have tried…
- I have nordvpn and mesh net and is not working.
2.i Did try with Tailscale again is not working.
- And I did reverse proxy with caddy and I can access the web UI of OHM but I can not make HA to communicate with it. I will share my config.yaml file and pls let me know what I can do and if you have any idea how to monitor sensors remotely.
4.I Did manage to open port on my router and put my public IP in host and it worked, but I can not make it to work with duckdns HTTPS that I get
platform: openhardwaremonitor
host: public ip
BR Boja
