Remote system monitoring
Does anyone have remote system monitoring setup? Looking for CPU temp/load, HDD temp (maybe), Disk space.
I have the system monitor for my Pi but want to also monitor my other server (Zoneminder, Fileserver) in HASS.
I’m not sure how to get the output from lm-sensors over to HASS. I also came across Webmin in my searches (http://www.webmin.com/index.html). Anyone heard of it or use it?
Would Glances work for you?
https://glances.readthedocs.io/en/latest/
Ah, I looked at Glances before but did not see the temp sensor. I see it now though so it should work. I have my server in a not-so-ideal place so I am worried about heat build-up.
Thanks once again @rpitera!
Awesome; glad I could help!
I have Glances running and ported into Hass per https://home-assistant.io/components/sensor.glances/ but I have not figured out how to get the temperatures in. I have been searching and digging through Glances docs & github but no luck with that or just trying to guess at the sensor name.
I personnaly use EzServerMonitor in script mode. But it also exist in web mode.
It allow me to get the result locally, by email or in a cloud.
It also allow to get the result (from the text log file) to trigger it.
Have a nice day.
Miguipda :wink:
hi @miguipda, have you some example of your exservermonitor work?
I want to monitor an other single board pc to my ha raspberry installation and your solution is very interest.
