I have flashed a Nedis IR remote sender (ESP8266) with ESPHome and learned some codes for my Krinner Christmastree lights, and that all works quite well. The problem is that everytime I install new code (update or juse a code edit install) the device emits IR signals at boot. Not sure why it does that? The problem is that it turns off my christmastree lights when I work on new IR codes for example … is there a way to disable this behaviour?
For reference here is my code:
substitutions:
devicename: ir-blaster-livingroom
friendly_name: Livingroom IR Blaster
# Set device attributes
esphome:
platform: ESP8266
board: esp01_1m
# Enable Wi-Fi connection
wifi:
ssid: !secret wifi_ssid
ap:
ssid: ESP-${devicename}
password: !secret esp_pw
# Enable captive poral
captive_portal:
# Enable websever
web_server:
port: 80
auth:
username: !secret webuser
password: !secret webpasswd
# Enable HomeAssistant API
api:
encryption:
key: !secret key
ota:
password: !secret ota_pw
# Enable logging without UART support as there would be no way to read it
logger:
baud_rate: 0
# Enable external blue LED as a status indictator
status_led:
pin:
number: GPIO4
# Enable the IR receiver to dump all IR commands to the log. Change dump type to your capture remote type. Use the captured IR command to replicate that IR command. You can disable this part when you aren't capturing IR command data.
#remote_receiver:
# pin:
# number: GPIO5
# inverted: true
# #mode:
# # input: true
# # pullup: true
# dump: raw
# Enable the remote transmitter
remote_transmitter:
pin: GPIO14
carrier_duty_percent: 50%
# Enable the underside button.
#binary_sensor:
# - platform: gpio
# pin:
# number: GPIO13
# inverted: true
# name: Underside Button
switch:
optimistic: true
assumed_state: true
turn_on_action:
# Data would be the IR command captured in the log by the remote receiver
- remote_transmitter.transmit_raw:
code: [2000,-1000, 400,-1000, 400, -400,1000,-1000, 400,-1000, 400, -400,1000,-1000, 400,-1000, 400, -400,2000,-5600,
2000,-1000, 400,-1000, 400, -400,1000,-1000, 400,-1000, 400, -400,1000,-1000, 400,-1000, 400, -400,2000,-5600]
carrier_frequency: 38kHz
repeat:
times: 5
wait_time: 16ms
turn_off_action:
code: [2000,-1000, 400,-1000, 400, -400,1000,-1000, 400,-1000, 400, -400,1000, -400,1000, -400,1000, -400,2000,-5600,
2000,-1000, 400,-1000, 400, -400,1000,-1000, 400,-1000, 400, -400,1000, -400,1000, -400,1000, -400,2000,-5600]
repeat:
times: 5
wait_time: 16ms
name: "Juletrelys Blinking"
optimistic: true
assumed_state: true
turn_on_action:
code: [2000,-1000, 400,-1000, 400, -400,1000,-1000, 400,-1000, 400, -400,1000, -400,1000,-1000, 400, -400,2000,-5600,
2000,-1000, 400,-1000, 400, -400,1000,-1000, 400,-1000, 400, -400,1000, -400,1000,-1000, 400, -400,2000,-5600]
repeat:
times: 5
wait_time: 16ms
