Tried relogging, I can’t log in again - I get the following error:
2020-02-22 13:27:35 ERROR (MainThread) [homeassistant.components.cloud.http_api] Unexpected error processing request for /api/cloud/login
File "/usr/src/homeassistant/homeassistant/components/cloud/http_api.py", line 129, in error_handler
result = await handler(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 50, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/cloud/http_api.py", line 196, in post
await cloud.login(data["email"], data["password"])
File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/__init__.py", line 179, in login
await self.start()
File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/__init__.py", line 237, in start
await self.client.logged_in()
File "/usr/src/homeassistant/homeassistant/components/cloud/client.py", line 120, in logged_in
gconf.async_enable_local_sdk()
File "/usr/src/homeassistant/homeassistant/components/google_assistant/helpers.py", line 210, in async_enable_local_sdk
self.hass, DOMAIN, "Local Support", webhook_id, self._handle_local_webhook,
File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 33, in async_register
raise ValueError("Handler is already defined!")
ValueError: Handler is already defined!
After refreshing the page though I appear to be logged in. It says it’s setting up remote UI but the status never changes. I found another error in the logs:
2020-02-21 14:11:54 ERROR (MainThread) [homeassistant.components.cloud.http_api] Unexpected error processing request for cloud/remote/connect
File "/usr/src/homeassistant/homeassistant/components/cloud/http_api.py", line 148, in error_handler
return await handler(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/cloud/http_api.py", line 452, in websocket_remote_connect
await cloud.remote.connect()
File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/remote.py", line 250, in connect
raise RemoteNotConnected()
hass_nabucasa.remote.RemoteNotConnected
