Hello, I have a Carrier Infinity HVAC system currently integrated with Home Assistant via an Infinitude proxy. I am interested in setting the thermostat’s ‘Current Temperature’ from an Average Sensor I have created (consisting of 3 Aquara Zigbee temp sensors scattered throughout the heat zone). Are there any straight-forward methods to do this and still maintain some thermostat functionality?
It depends - if there is a switch to turn the heating on and off - then just use a generic thermostat.
This is mine:
climate:
- platform: generic_thermostat
heater: switch.house_boiler
target_sensor: sensor.average_house_temperature
min_temp: 14
max_temp: 25
min_cycle_duration:
minutes: 15
initial_hvac_mode: "heat"
away_temp: 16.5
cold_tolerance: 0.3
hot_tolerance: 0.3
keep_alive:
minutes: 5
precision: 0.1
