Hello all,
I try to configure a Remotec ZRC90.
I followed the doc here: https://www.home-assistant.io/docs/z-wave/device-specific/#remotec-zrc-90-scene-master but can’t get it work.
Does anyone got one up and running?
Here are the details of my automation configuration:
- id: '1582542651553'
alias: bouton2
description: test bouton 2 commande_bas
- event_data:
node_id: 9
scene_data: 0
scene_id: 2
event_type: zwave.scene_activated
platform: event
condition: []
- data:
message: Commande bas
title: Test Commande bas
service: notify.gmail
I can see the events in OZW_Log.txt:
2020-05-02 12:44:10.730 Info, Node009, Received Central Scene set from node 9: scene id=2 in 0 seconds. Sending event notification.
Then I can see some logs about my automation in the logs but it’s not getted executed:
2020-05-02 12:54:34 INFO (MainThread) [homeassistant.components.automation] Initialized trigger bouton2
2020-05-02 12:54:34 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=automation.commande_bas, old_state=None, new_state=<state automation.commande_bas=on; last_triggered=2020-05-02T12:24:39.579180+02:00, id=1582542651553, friendly_name=bouton2 @ 2020-05-02T12:54:34.974871+02:00>>
2020-05-02 12:54:34 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.2934058480] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=automation.pressalleautom, old_state=None, new_state=<state automation.pressalleautom=on; last_triggered=2020-05-02T12:54:16.655239+02:00, id=1576792551543, friendly_name=presSalleAutom @ 2020-05-02T12:54:34.964676+02:00>>}
2020-05-02 12:54:34 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.2934058480] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=automation.presence_terrasse_1, old_state=None, new_state=<state automation.presence_terrasse_1=off; last_triggered=2020-01-04T15:21:28.488662+01:00, id=1577051634166, friendly_name=presence terrasse 1 @ 2020-05-02T12:54:34.967745+02:00>>}
2020-05-02 12:54:34 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.2934058480] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=automation.presence_terrasse_2, old_state=None, new_state=<state automation.presence_terrasse_2=off; last_triggered=2020-02-24T13:09:48.741632+01:00, id=1577989366891, friendly_name=presence terrasse 2 @ 2020-05-02T12:54:34.970592+02:00>>}
2020-05-02 12:54:34 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.2934058480] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=automation.commande_bas, old_state=None, new_state=<state automation.commande_bas=on; last_triggered=2020-05-02T12:24:39.579180+02:00, id=1582542651553, friendly_name=bouton2 @ 2020-05-02T12:54:34.974871+02:00>>}
I can’t find a lot of feedback about this device in HA, so if you have some and have an idea of what I’m doing wrong, please let me know!
Thanks in advance!
