Hello all!
Many years ago I started one automation using FHEM. It’s running in a Raspi 4B with recent Raspberian (based on Debian bullseye). Last spring I discovered HA and loved the interface, which also has a high WAF (woman acceptance factor). I installed HA on the same Raspi as FHEM, but in a docker. The installation is with supervisor which was supported till last autumn.
Since the policy for installation of supervisor has changed a couple of moths ago I can’t update the supervisor-component either and sooner or later it will be very outdated.
I’m considering a new installation of my system from scratch w/o supervisor (but still using HACS). However, I am worried about the onboarding when I’m going to import the last backup. Will it be a problem to onboard a configuration which was made with supervisor installed in a fresh installation without supervisor installed?
Furthermore; what does it mean for me having an installation w/o supervisor (e.g.: Raspberry Pi - Home Assistant ) ? Is there much more effort to maintain the system than today?
Thank you for your answers!
