Remove a switch button of a room card
Hello, new to HA, my question might be dumb, but I can’t find any subject related to this point.
I don’t know how, but one of my room card “Cellier” has a global room switch visible near the title on the default overview dashboard. This switch is tight to a device entity switch named “Heures pleines PAC”. I can’t find any parameter neither on the entity nor the room to remove this global switch attached to the room card.
Could someone help me find a way to remove this switch from the room card title please?
Sorry if I’ve missed something very obvious in the documentation or community forums but my searches give no results.
Regards
Edit this Card
Use Code Editor and delate this line
„show_header_toggle: true“
Or just switch it off in the UI
Hello, thanks, however this card is from the Default overview dashboard, I have no access to the card parameters nor the code. I can effectively see this parameter when using a custom dashboard on entities cards.
Any clue?
If you want to change the dashboard you have to take control of it.
You can’t alter the auto generated dashboard without doing this.
OK I understand.
However how could we explain that on the default dashboard, a room on card has a different behaviour than all other rooms? There must be a parameter related to devices or entities attached to this room but I can’t figure where it comes from.
The difference is that it has switches in it.
