Remove an item from a card
I added a card from the device page, and my options were to add either or both of two cards, so I did. But there are many items in each card that I don’t want to see. Is there a way to edit the cards, or just add the entities that I want. I tried looking at the entities page, but didn’t see a way to add an entity to a card.
Not clear what you mean by this - could you be more specific?
When I added the card from the device page for my lucid custom integration, the card had all the sensors included in the integration, most of which I don’t care about. If I go to the entities page and try to add one of the sensors from there, it doesn’t seem to give me that option. So, either I need a way to add a single entity to a card/view, or I need a way to edit a card and remove/hide some of the items in it.
I don’t think you’re supposed to be able to edit those cards. You can disable sensors, in which case they will not be displayed, but they won’t be added to HA at all, so you won’t be able to use them. You can hide them, but they are only hidden in dashboards - they still appear on the device page.
Both those options can be reached by clicking on an entity and editing it.
I tried just hiding them, but they still show up in the card.
Is there some other way I can create a view that will only have the sensors that I am interested in?
Er… a dashboard? :grin:
I did create a dashboard, then added the device from the integration, and that is what gave me the cards that I can’t modify. I can’t find a way to just add and entity to the dashboard I created. Is this possible?
I’m sorry - suddenly I see what you mean. :flushed:
Don’t click on “Add to Dashboard”. Go to the dashboard, click “Edit” (top right) and “Add card” (bottom right), select the card you want (probably “Entity” or “Entities”) and add the entities you want to the blank card.
Not sure what changed (maybe when I added the new card, but now I can edit the new card and remove/delete/reorder the entities, either visually of in Yaml.
Thanks for the help.
