Remove attributes of sensor
Guys, is there a way to remove from a sensor card the node_id, value index, value instance and value id(see below)
This sensor contains a value from a zwave device
BUMP.
Anyone have a solution to this?
With the updates between your first post and now, the attributes should all be nicely rolled up under one expandable heading now.
If you want to remove that completely you will have to design your own pop-up more info cards using browser mod.
