Remove Connect ZBT from HA Config
I installed a HA Connect ZBT to act as my Zigbee controller but after a couple days, I removed the USB to move the device. Now when I plug the device back in, HA doesn’t see the USB device. I have sent it back to get a replacement but the entry is stuck in the Hardware section and I can’t remove it.
How do I remove this?
Is there already a solution for this?
I found a way to remove the device: There were three ZHA-1 entries under .storage/core.config_entries. I deleted the entry whose ID did not match the one displayed under “All Hardware”.
See also: No way to remove the ZBT-1 from Home Assistant · Issue #5384 · home-assistant/supervisor
