Hi all,
is there a way to remove a device from Google Home? I mean without unlink ALL devices and re-link them.
Thanks in advance
You can send a command as sync devices and google home will check all updates including both additions and removals. When i do some changes in entities inside home assistant, i use this voice command and it works.
Second option is to disable the device in google home.
Third option is to filter respective entities in home assistant google integration configuration.
ok, thanks, my mistake: those devices were still present in HA, so they were correctly present in GH. I removed them from HA and after a reboot they disappeared from GH too.
