I am new to all of this. Bought a RaspberryPi 3B+. Installed the image file on an SD card and got going. This is working ok. But there are a lot of things that I do not know how to do and I need help. Again, I am a complete beginner so I need super simple instruction (thanks).
I can reach Home Assistant from my Mac or directly from the RaspberryPi. When connected to the RaspberryPi I am asked to login on HassOS. I have no alternative to doing that.
I have HA version 0.75.3.
- I tried to setup HomeKit with HomeKit: and it worked so far as that I received a code and could enter it into the Home app. The code was accepted but the bridge was never added (the wheel kept spinning). It says that I should remove .homekit.state. I do not know how to do that.
- It says that I might have to download a package with the following command:
$ sudo apt-get install libavahi-compat-libdnssd-dev
I do not know where to enter the command.
I would really appreciate hela with this!
