Remove Integration not configured
Not sure how it got there as I’m still on the legacy Z-Wave 1.4 built in integration, but it’s kind of getting in my way of freeing up the z-wave stick and want to have a clean start before configuring Z-Wave 1.6. So for some reason Z-Wave JS shows installed and not configured. So I can’t remove it.
Any way to get rid of this Z-Wave JS Integration?
That shows a USB device was discovered that can be used with Z-Wave JS integration. Nothing is installed, you just click the IGNORE button to dismiss it.
Sure? Just in my brain if the Z-Wave JS integration isn’t installed wouldn’t think the Z-Wave JS integration would be finding things. But just my thought.
The device is being found by USB discovery. USB Discovery - Home Assistant. Based on the device type it suggests the Z-Wave JS integration. The Z-Wave JS integration is not doing anything, because it isn’t installed.
