I want to disable LTS for single entities which are provided by an integration.
This means, there’s no state_class
set manually (to measurement
or total
etc.) in any YAML which now could be removed. And following Sensor Entity | Home Assistant Developer Docs, there’s no state_class: none|empty|...
or sth. like that.
So: how to remove LTS?
I don’t need it to be stored forever in the database, as I
- use the entities data only in a separate template sensor (which does some calculations) and
- the original entities create unnecessary LTS in the database - for really no benefit next to database capacity. (as I copy it, I don’t think refusing to store its values in the recorder at all is not a good idea, isn’t it? well, this question is another one anyway)
Example (does not anything valuable to the original question, just for my own reference):
sensor.fritzbox_XXXX_kb_s_received
from the AVM FRITZ!Box Tools integration. Just a random example.
