I’ve switched from Zwave2mqtt to ZwaveJS & the old menu of zwave2mqtt was not removed when I uninstalled it.
I know I can’t hide it but I rather remove it.
in the configuration.yaml file
do you have a
panel_iframe:
with a Zigbee2mqtt
or and you can turn it off in the unfo section on the Zigbee2mqtt
My bad, my screenshot is not the best one.
It’s Z-Wave to MQTT that bothers me, not Zigbee .
But Zwave2Mqtt is deprecated & I don’t think I can install it anymore.
So, no way to remove it cleanly ?
If I try to create a false component & remove it after, will it works ?
